LR4x4 - The Land Rover Forum: Help!! V8 not starting after tdi to V8 swap (video inc) - LR4x4 - The Land Rover Forum
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   Davecrx
  • Member
  • PipPip
  • Group: Settled In
Posted 17 December 2009 - 10:26 PM
Hi
I've just done the engine swap on my disco. tdi to V8
All seems to be working, sparks and got fuel in the fuel lines.
But when I crank it over it starts to fire up but the stalls after a few seconds.
Check the video out as your get a better idea about what I mean.
95 Land rover discovery 300 with tdi removed and a V8 added in Green.
Soon to be running MS
#2 User is offline   Bowie69
  • Permanently befuddled....
  • PipPipPip
  • View gallery
  • Group: Settled In
Posted 17 December 2009 - 10:45 PM
White/black wire going to negative side of coil is quite probably missing -this tells the ECU that the engine is running and therefore injects fuel, it pokes out of the FM plug on hotwire, probably the same on crapper.
The fact you get it running for a few seconds indicates your cold start injector is doing it's job, but no more fuel is getting through.
1980 2.25 Petrol FFR Lightweight (standard)
1991 (late) Range Rover Classic Vogue SE,4.0 Serp cross-bolted V8, MegaSquirt, LT230, 33" Simex JT2s, X-Brake, Full cage, tank guard, tree sliders, TDS 9.5 with Bow1, Southdown front bumper, HD rear bumper, Ali rear floor, Ali rear tailgate, Twin electric fans, cage mounted X-lites.
#3 User is online   FridgeFreezer
  • Ferpect
  • PipPipPipPip
  • Group: Settled In
Posted 18 December 2009 - 02:10 AM
Tech archive, V8 Flapper EFI diagnostics manual, work through it.
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
