Antifreeze questions.
  • Please log in to reply
11 replies to this topic
#1 kingdong2
kingdong2
    Old Hand
  • Settled In
  • PipPipPip
  • 378 posts
Posted 27 April 2010 - 04:39 PM
Hi guys
A few questions.
1,how much antifreeze does my 03 disco 2 td5 hold, 2 1/2lts ?
2,do i need to buy it from a land rover dealer.
3,if not what make of antifreeze is best and where to buy it from ( halfords )
4,what type of antifreeze do i need.
i have ordered a top rad hose and a bottom rad hose from paddocks as the bleed screw is striped in the top hose and is leaking, so thought i would replace both hoses at the same time as we are going to cornwall in july.
graham
__________________
03 d2 td5 auto e.s.
97 d1 300 tdi man.
#2 jbs
jbs
    Old Hand
  • Long Term Supporters
  • 1,665 posts
Posted 27 April 2010 - 04:49 PM
Don't get it from Halfords as it'll cost you nearly twice as much as a car parts place does- I went to get some last night and it was at least 9 cheaper than halfords
John
You have the capacity to learn from your mistakes. You will learn a lot today.
#3 Wolfie69
Wolfie69
    Member
  • Settled In
  • PipPip
  • 61 posts
Posted 27 April 2010 - 06:12 PM
according to haynes you need'ethylene glycol based with oats[organic acid technology] corrosion inhibitors'
I went to my local carparts place and bought 5lts for about £25
it does not state what strength but the more the better
#4 pw8757
pw8757
    Old Hand
  • Settled In
  • PipPipPip
  • 304 posts
Posted 27 April 2010 - 07:01 PM
The mix ratio can be worked out by reading the container. That will give you the lowest temperature you will keep being protected at. I always go for the lowest temp I'm likely to encounter (bearing in mind I will probably go to the Alps in the winter!).
Same sort of thing applies to screenwash. More fluid if its colder. Helps to stop the washers freezing.
I usually get mine from a motor factors, rather than a superstore. Better value for money. Unless you are really stuck (or you have to get the change done as part of a service or repair), don't buy it from a dealer. That's where they really make their money!
My wife has an Audi TT and their stuff is frighteningly expensive!!
PW8757
Discovery 1997 V8 3.9 efi - Under Rebuild - Daily Driver is a Toyota IQ2 !
SuperSkills
#5 WESTENDER
WESTENDER
    Member
  • Settled In
  • PipPip
  • 136 posts
Posted 27 April 2010 - 07:24 PM
"the more the better" is not correct if you put in antifreeze at too strong a mixture it is too thick to effectively conduct the heat away and will boil very easily, it is worth finding out the correct proportions as requires by the maker
and going with that
#6 ches
ches
    Member
  • Settled In
  • PipPip
  • 106 posts
Posted 27 April 2010 - 08:16 PM
have read some data sheets from different manufacturers of OAT and it should be diluted with deionised water.
#7 dooroy
dooroy
    Old Hand
  • Settled In
  • PipPipPip
  • 210 posts
Posted 28 April 2010 - 01:12 AM
Anti freeze does more than just preventing the water from freezing - it lubricates and prevents corrosion also .
I use a 50/50 mix and as far as I can remember that's what LR recommend .
Having been charged crazy prices by LR for the proper afreeze I read up a bit and now use Comma Longlife afreeeze which I buy from the motor factors in 5L cans - LR could only supply 1L bottles at something like 14 each .
#8 kingrat
kingrat
    Member
  • Settled In
  • PipPip
  • 195 posts
Posted 29 April 2010 - 02:48 PM
Don't knock Halfords too much they had it on offer pre mixed last year on a 3-4-2 that made it 34 for 15 litres which is not that bad for OAT
Paul
#9 disco_al
disco_al
    Old Hand
  • 1,867 posts
Posted 29 April 2010 - 03:12 PM
not bad, but then we sell 20 litre drums of oat for 39.....
1998 Disco 1 300 TDi ES Spec in Oxford Blue - Steering Guard, Safari Snorkel, T-Max Split Charge System, Allisport Full Width Intercooler, Tweaked Injector Pump, TD5 Headlight Upgrade, EGR Removed, Stainless & Silicone Hose Kit, De-Cat Pipe, A Bar, 2" Lift with Procomp ES9000's, Bearmach HD Blue Springs, BFG AT's in 235/85/16 flavour and more to come......
#10 gripper
gripper
    Member
  • Settled In
  • PipPip
  • 139 posts
Posted 29 April 2010 - 05:59 PM
i've heard that the anti freeze doesn't actually transfer heat away it is the water that's mixed with it that does that, it just stops that water from freezing and stops the engine from rusting inside, that's why putting too much anti freeze in is worse than the correct amount as it has less heat transference than the correct mix and will run hotter than it should..
#11 kingdong2
kingdong2
    Old Hand
  • Settled In
  • PipPipPip
  • 378 posts
Posted 29 April 2010 - 08:09 PM
ended going to land rover in stockport as all the local motorist shops didn't know what i was on about ( OAT ) 35 for 5 lts.
graham
____________________
03 d2 td5 auto e.s.
97 d1 300 tdi man.
#12 Paul101
Paul101
    Newbie
  • New Faces
  • Pip
  • 6 posts
Posted 02 May 2010 - 12:26 PM
Carplan do 5year OAT (Pink) at just under 20 for 5 ltrs.
I think you need 7ltrs neat for a 50/50 complete fill, it takes 13 ltrs.
Empty it all the system and flush, but NOT high pressure.
Got this to do next month with oil/filter changes.
