Fitting Mud Flaps
  • Please log in to reply
4 replies to this topic
#1 WarPig
WarPig
    Member
  • Settled In
  • PipPip
  • 107 posts
Posted 05 October 2010 - 09:38 AM
The mud flaps on my 110 were removed by mechanic a few weeks ago, and now I want to fit some new ones. But I never studied how they were fitted :unsure:
For the rear flaps, I can see a bolt under the lip of the rear wing which I guess is used by one end of the bracket, so does the other L-shaped end of the bracket fit against the lashing eye bolt on the chassis?
And does the bracket for the front flaps fit in a similar way?
Many thanks
1996 Defender 110 300tdi Commercial Station Waggon/Utility
#2 oakesy
oakesy
    Member
  • Settled In
  • PipPip
  • 170 posts
Posted 05 October 2010 - 03:05 PM
On the part of the chassis I did not have any mud flaps but I attached mine halfway between the support strap and the rear section. For the front on the outrigger via two nut and bolts hope this helps. hopefully a grownup will offer better advice and pictures. :D
Ðonc for eower ærende.
Glæd Tid fram john n oakes.
#3 western
western
    Recovery Man
  • Moderators
  • 30,809 posts
Posted 05 October 2010 - 05:23 PM
fits into a threaded rivnut in the chassis side face, not on the lashing point bolt
pages 1073 & 1074
Ralph, M3WRM, MSA Recovery Operator -- Western Recovery [Motorsport] http://www.amro.org.uk/
Defender Forum Moderator
Keep LR4x4.com Independent -- you can help by Clicking Here
#4 WarPig
WarPig
    Member
  • Settled In
  • PipPip
  • 107 posts
Posted 05 October 2010 - 06:48 PM
oakesy, thanks for posting the photos, much appreciated :)
western, I dont seem to have a threaded rivnut on my chassis. Its a Richards galv chassis and it seems they've missed this hole off :( or its filled with galv.
Guess I'll have to decided whether to drill a hole in the galv, or go without mudflaps :(
#5 western
western
    Recovery Man
  • Moderators
  • 30,809 posts
Posted 05 October 2010 - 06:55 PM
you'll probably have to drill a hole & fit a rivnut or engineer a alternative way of attaching the mudflaps, you could mount the as on a 90 using the rear cross member instead of the 110's rear vrackets.
