Coil spring conversion
  • Please log in to reply
15 replies to this topic
#1 ludylandy
ludylandy
    Member
  • Supporters
  • 45 posts
Posted 03 April 2011 - 08:39 PM
I went to the Newbury sort out today and one of the stalls had a rear axle coil spring conversion for a SWB series. I've never seen one before and just wondered if anyone else has experience of them.
#2 P H Services
P H Services
    Member
  • Settled In
  • PipPip
  • 23 posts
Posted 04 April 2011 - 10:58 AM
I had one for a while it was half a leaf spring that was fixed at the front end and protruded out behind the back of the axle which is where the coil spring was mounted. The top mounting was a channel that fitted over the chassis and was drilled and then bolted through the chassis to locate it. It did work well greatly improved the ride but i could of done with better shock absorbers on the back as they didnt damp very well and was a bit bouncy !!!! All in all it worked very well and i was pleased with it.
#3 tuko
tuko
    Good old Boy
  • Settled In
  • PipPipPip
  • 1,183 posts
Posted 04 April 2011 - 01:31 PM
Rear axle coil spring conversion kits use to be advertised in LRO in the early days, I'll see if I can did up an old ad.
Todd.
This is a technical forum, NOT a social networking site
My 300Di Series Hybrid
The Swedish Outback :SOAoutback.se
#4 FridgeFreezer
FridgeFreezer
    Director of authenticity
  • Supporters
  • 15,456 posts
Posted 04 April 2011 - 01:55 PM
That sounds, erm, quite nasty :ph34r:
Yes*
*No
#5 MattMatt
MattMatt
    Member
  • Settled In
  • PipPip
  • 50 posts
Posted 04 April 2011 - 04:28 PM
Agreed - where does it get side to side strength from? Surely the whole axle could move about without the rear shackles?
#6 Retroanaconda
Retroanaconda
    Old Hand
  • Long Term Supporters
  • 4,742 posts
Posted 04 April 2011 - 06:20 PM
There was a panhard rod too, to locate the axle horizontally.
Not sure I'd want to go to all that bother myself :P
#7 Snagger
Snagger
    Old Hand
  • Settled In
  • PipPipPip
  • 1,605 posts
Posted 06 April 2011 - 12:45 PM
A decent set of parabolics and gas dampers would be easier, safer and less likely to raise eyebrows from MoT inspectors, police or insurers.
www.nickslandrover.co.uk
#8 Muttland
Muttland
    Member
  • Settled In
  • PipPip
  • 59 posts
Posted 08 April 2011 - 03:34 PM
http://www.designa-c...o.uk/88coil.asp
Posted Image
Serie III 109 / Híbrido con Def.
Posted Image
#9 Mike Brownlie
Mike Brownlie
    Member
  • Settled In
  • PipPip
  • 75 posts
Posted 12 April 2011 - 01:59 PM
Posted Image
New chassis made for that function I think is the best way to go.
1. Its a new chassis and even though your changing suspension components, you have enough points to avoid "Q" plate.
2. Modifying your own chassis is a little risky on suspension geometry etc, and also would gain a "Q" plate, and need SVA test.
#10 Phil Hancock
Phil Hancock
    Old Hand
  • Settled In
  • PipPipPip
  • 1,187 posts
Posted 12 April 2011 - 06:08 PM
But its not the original spec as it has coil mounts, very grey area and who is going to be the test case in court.
#11 FridgeFreezer
FridgeFreezer
  • Supporters
  • 15,456 posts
Posted 12 April 2011 - 06:48 PM
If you've ever cut a coiler chassis apart there's an awful lot of internal bracing and double-skin bits inside, all there for very good reasons, and simply not possible to achieve if you convert one yourself.
Yes*
*No
#12 RobotMan
RobotMan
    Old Hand
  • Settled In
  • PipPipPip
  • 382 posts
Posted 12 April 2011 - 07:22 PM
I have a Designa chassis standard galvanized. Its nice and has survived serious abuse.
Wouldn't bother with the coiler conversion nowadays.
Rob (Robotman) Taylor.
http://www.monkeymotorsport.co.uk
#13 Mike Brownlie
Mike Brownlie
    Member
  • Settled In
  • PipPip
  • 75 posts
Posted 13 April 2011 - 12:03 AM
No grey area at all.
If you use a brand new chassis and provide a receipt to prove,(from a recognised chassis manufacturer) even though its non standard worst case scenario is an SVA. They can not issue a "Q" plate because the chassis is new manufactured and not a modified DIY affair. The purpose of the system is to avoid DIY cut and shut suspension/chassis mods and you would not be penalised for using a new chassis.
It may require to be re-registered, but as the chassis is new "Q" plate is avoided.
#14 Snagger
Snagger
    Old Hand
  • Settled In
  • PipPipPip
  • 1,605 posts
Posted 14 April 2011 - 04:45 PM
That logic wouldn't stop a 90 being rebuilt as a 130 or a 1958 SII being rebuilt as a 2011 Defender. The specs of the chassis have to match the original too - it's not just a matter of it being brand new.
#15 Phil Hancock
Phil Hancock
    Old Hand
  • Settled In
  • PipPipPip
  • 1,187 posts
Posted 14 April 2011 - 06:14 PM
Hence my comment.
#16 Mike Brownlie
Mike Brownlie
    Member
  • Settled In
  • PipPip
  • 75 posts
Posted 15 April 2011 - 12:58 AM
It falls under the catagory of Kit Conversions;
Kit Conversions
This is where a kit of new parts is added to an existing vehicle or old parts are added to a kit comprising a manufactured body, chassis or monocoque bodyshell. The general appearance of the vehicle will change and result in a revised description on the registration certificate.
A vehicle will retain its donor registration mark if either the original unmodified chassis or unaltered monocoque bodyshell and two other major components are used. If a new monocoque bodyshell or chassis from a specialist kit manufacturer is used (or an altered chassis or bodyshell from an existing vehicle) together with two major components from a donor vehicle, an age related mark will be assigned. The mark will be based on the age of the donor vehicle. An IVA, ESVA, SVA or MSVA test will be required to register the vehicle.
Where there are insufficient parts from a donor vehicle or in cases where the original registration mark is unknown, an IVA, ESVA, SVA or MSVA certificate will be required to register the vehicle and a 'Q' prefix registration number will be allocated.
I can get extracts from the manuals if you feel this is not enough. But the chassis from designa would be considered a "Kit Conversion"
I would make sure though that whatever you do regardless of either chassis or modifications ensure all engine numbers match those on the v5 as its a proper headache if they are queried.
