TD5 Ride Height Sensor Arms
#1
Posted 26 April 2011 - 08:39 PM
Can you buy those arms separately or do you have to buy the complete sensor unit?
The arms are still attached, but only just and the sensors are still working.
Cheers
Matt
#2
Posted 26 April 2011 - 09:13 PM
item 11 on http://www.numcat.ru...ver/p/33/45936/
only supplied like this click the part number RQH100030 to see the arm.
Defender Forum Moderator
Keep LR4x4.com Independent -- you can help by Clicking Here
#3
Posted 26 April 2011 - 10:22 PM
It's that round bit at the bottom that's snapped/cracked on both sides. (which attaches to bolt number 12 in the diagram)
#4
Posted 26 April 2011 - 10:47 PM
I don't know if that eye end will unscrew or if it's moulded on to the rod.
#5
Posted 27 April 2011 - 05:35 AM
Les.
#6
Posted 27 April 2011 - 08:19 AM
Top tip from me would be measure your current ride height before doing anything, just in case it needs resetting.
Think I paid £24 each for the sensor.
#7
Posted 27 April 2011 - 12:15 PM
You have to buy the whole thing, but they aren't too expensive. Be very careful when unplugging the old one as the plug and socket are very thin plastic and can easily break. Also - disconnect the battery before you start as you may get a warning light on the dash if the arm goes out of range while still connected.
Les.
If you do manage to damage the loom connectors, replacements are available.
FamousFour do a Connector Repair Kit, their Part Number FF005834 -
http://www.famousfou...hp?partID=12579
Or, if you're OK with crimping small terminals, just the connectors can be bought from Simtek, their Part Number CON-081
http://www.simtekuk....search=&sought=
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
#8
Posted 27 April 2011 - 03:59 PM
Range Rover Classic TDi "Chuggaboom"
Range Rover Vogue 3.9 "Blue" with many toys & a GKN-Sankey Rapier
