Water leak under the dashboard
  • Please log in to reply
23 replies to this topic
#1 Tetsu0san
Tetsu0san
    Old Hand
  • Settled In
  • PipPipPip
  • 620 posts
Posted 26 May 2011 - 06:53 PM
Hi all
This is a job I have been putting off for a while, but with the heavy rain today I was getting a wet foot while driving, so I need to remove the dash to see where the rain is coming in, and to repair a couple of holes that I can see.
How easy is it to remove the dashboard? What do I have to remove to get access to the bulkhead from the inside?
Cheers
'M' reg Discovery 300Tdi - 'K' reg Defender 90 200Tdi - 'L' reg Discovery 200Tdi
'B' reg Land Rover 110 200Tdi - Pride and joy
'R' reg BMW 525tds se - Daily driver
#2 western
western
    Recovery Man
  • Moderators
  • 30,790 posts
Posted 26 May 2011 - 07:18 PM
before stripping the entire dash out, check these areas.
outside on bulkhead below windscreen, there should be 2 rubber buffers that the bonnet rear edge butts against, if these are missing water can get into the cab more here
remove fusebox cover, pull back mat from the sides there should be 2 oval rubber grommets [one each side] replace if missing or ripped/punctured item 5 page 750
there should be a rubber gasket around the holes where the clutch & brake pedal units come in to the cab make sure these are intact or use a suitable sealaant between the pedal box units & bulkhead. clutch item 13 on page 476 & brake item 10 on page 478
Ralph, M3WRM, MSA Recovery Operator -- Western Recovery [Motorsport] http://www.amro.org.uk/
Defender Forum Moderator
Keep LR4x4.com Independent -- you can help by Clicking Here
#3 reb78
reb78
    Old Hand
  • Supporters
  • 3,693 posts
Posted 26 May 2011 - 07:35 PM
Mine also leaks through the windscreen rubber and this trickles in and then down into the footwell giving the impression the leak is lower down.
Richard
1989 110 - Defender 200tdi (ex 19J), LT77s, LT230 (from a TD5) & GKN overdrive
2004 D2 TD5 Landmark
#4 Tetsu0san
Tetsu0san
    Old Hand
  • Settled In
  • PipPipPip
  • 620 posts
Posted 26 May 2011 - 07:58 PM
Cheers for all that info, that is very helpfull. I think I see the problem now though. Where the channel behind the bonnet lets water run off the side, it goes down the joint between the wing and the bulkhead and down the side of the footwell. There is a pretty big hole there which is probably where the water is coming in. It then runs along the plastic under the dash and onto my foot. Wing off as well as dash out I think.
I also want to get to some holes on the inside in the top corners by the windscreen hinge bolt holes. Usually this is on the outside, but not on mine!
#5 slihp
slihp
    Old Hand
  • Settled In
  • PipPipPip
  • 280 posts
Posted 26 May 2011 - 08:29 PM
Teti did this job in the last two weeks, before fitting new carpets wanted to find out where the water was getting in so stripped the cab back to bare, seats dashboard the lot. The full dashboard can be taken off in a morning. Im glad i did it as i could see water trails that would have been hidden. Also allowed me to hammerite any rust that the water ingress had causedmy grommets were ok but the one in the passengers footwell was missing. but it turns out my watter was coming from bad seals on the windscreen vents. 11 replaced them and IM DRY NOW
2001 TD5 Defender 90 Truck Cab
#6 SH4RKY
SH4RKY
    Member
  • Settled In
  • PipPip
  • 40 posts
Posted 26 May 2011 - 10:39 PM
There is a Tech Guide about how to remedy leaks on landroverweb.com
Hope this link works:
Defender Water Ingress Manual
Need to sort a few leeks on mine before i bother fitting any sort of interior. Went round a corner earlier today and literally got rained on from the top of the door... :)
#7 western
western
    Recovery Man
  • Moderators
  • 30,790 posts
Posted 27 May 2011 - 01:58 PM
Also in out Tech Archive index too :i-m_so_happy:
#8 brighouse shed
brighouse shed
    Old Hand
  • Supporters
  • 282 posts
Posted 27 May 2011 - 05:02 PM
if you want to get dash off grab the instructions from the LR radio fitting kit, lots of piccies and straightforward.
If you can't find one pm me and i'll do a dig and scan it for you
1991 Defender 90 200TDi
#9 simonr
simonr
    Trainee shepherd
  • Supporters
  • 5,592 posts
Posted 28 May 2011 - 08:05 AM
I thought the built in Shower was a feature ;-)
Si
#10 Tetsu0san
Tetsu0san
    Old Hand
  • Settled In
  • PipPipPip
  • 620 posts
Posted 28 May 2011 - 08:19 AM
That is why I have put it off soo long. A friend has a 54 plate 110, top of the range spec, ex demo vehicle and that leaks too. Not as bad, but still a wet foot on occasion.
I am sure they must have a part number for a water leak, same as they have for oil...
#11 Retroanaconda
Retroanaconda
    Old Hand
  • Long Term Supporters
  • 5,796 posts
Posted 28 May 2011 - 05:51 PM
The only leaks left in my 90 are the footwells, I'm 99% sure it's coming from the windscreen seal (badly perished at the corners like they do) and the windscreen hinge bolts (the gaskets for those have long perished too).
The plan is to have it all off when I get a chance and replace them both, plus the screen-to-bulkhead seal, and hopefully that'll see me dry in the rain!
#12 JimAttrill
JimAttrill
    So important that they banned 50 000 IP addresses to shut me up
  • Settled In
  • PipPipPip
  • 2,909 posts
  • Location:S 2601.3' E02758.5 1373m Johannesburg, South Africa
Posted 28 May 2011 - 11:12 PM
I thought my leak was from a perished windscreen seal until I had a new windscreen and seal fitted. The leak must be from somewhere else. I also have looked at the ingress manual which is of some help. Luckily it doesn't rain much here :rolleyes:
1996 Defender 300Tdi 110 csw
#13 Challo
Challo
    Member
  • Supporters
  • 140 posts
Posted 29 May 2011 - 09:16 PM
I had a leak earlier this year, which I thought was coming from the bulkhead. Eventually traced it to the throttle cable, a grommet was missing, but an easy fix nonetheless.
#14 ivanlrlukic
ivanlrlukic
    Member
  • Settled In
  • PipPip
  • 75 posts
Posted 25 November 2013 - 09:29 AM
I'm lacking those rubber buffers too. It seems I cannot find their p/n in my parts book. Anybody has it handy?
#15 lr110katy
lr110katy
    Newbie
  • New Faces
  • Pip
  • 6 posts
Posted 25 November 2013 - 12:34 PM
I think I might have a leak
#16 Paddy
Paddy
    Member
  • 167 posts
Posted 25 November 2013 - 06:19 PM
Ralph, I tried this a while ago and got a 404 error, The Defender water ingress manual is down or missing.
Military Defender 90
#17 Mo Murphy
Mo Murphy
    Broad Minded
  • 6,590 posts
Posted 25 November 2013 - 07:50 PM
Looks normal to me ;)
The Land Rover 90: Many are called, few are chosen ...
Fifty Shades of Pennine grey
#18 Anderzander
Anderzander
    Old Hand
  • 4,020 posts
Posted 25 November 2013 - 08:21 PM
On my phone I can't make head nor tail out of that picture ?
 I have an oven with a 'stop time' button. It's probably meant to be 'stop timer' but I don't touch it, just in case.
#19 western
western
    Recovery Man
  • Moderators
  • 30,790 posts
Posted 25 November 2013 - 08:50 PM
Here you go Paddy, a new link http://www.landrover...ress_Manual.pdf
#20 western
western
    Recovery Man
  • Moderators
  • 30,790 posts
Posted 25 November 2013 - 08:51 PM
left hand front footwell, full of water by the look of it
