Chassis Numbers
  • Please log in to reply
18 replies to this topic
#1 Tris Cocks
Tris Cocks
    Old Hand
  • Settled In
  • PipPipPip
  • 272 posts
Posted 02 June 2011 - 11:00 AM
Ive had my 300TDi defender for about 3 years now and it has gone through the previous MOTs without just the normal small issues, loose ball joint, worn steering bush etc. However during the last MOT i had a letter come throught the door a week or so later saying that there was a discrepency in the Chassis numbers between the vehicle, V5 and the MOT certificate, It seems that i have got two Chassis numbers :unsure:
Upon further inspection i have found that the chassis number on the Vin plate matches the MOT certificate.... But the number stamped on the chassis dumb iron matches the V5 :unsure:
If i post the chassis numbers on here is it possible to work out which one is correct so that i have a heads up before the DVLA come knocking?
Cheers
Tris
1998 Defender 90 CSW
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
#2 Les Henson
Les Henson
    Still waiting to weld my new chassis :(
  • Supporters
  • 12,930 posts
Posted 02 June 2011 - 11:40 AM
Chassis No is what you go by usually. Body panels are not really counted, so second hand parts might have been fitted - hence the wrong plate. I had a S3 that had 3 different VIN Numbers :). You can buy the plates I think, and stamp the correct number on it yourself.
Might be too late now - the DVLA and/or Police might come round and kick your door in :(
Les.
Keep this forum independent click here.
#3 SPendrey
SPendrey
    Old Hand
  • Long Term Supporters
  • 822 posts
Posted 02 June 2011 - 11:48 AM
Maybe try here...
http://www.motoverse...n/landRover.asp
...or here...
http://www.disgruntl...rVINchecker.php
#4 Snagger
Snagger
    Old Hand
  • Supporters
  • 3,273 posts
Posted 02 June 2011 - 04:37 PM
I'd agree with Les - the chassis is more likely to be the original VIN as the brake pedal unit with the VIN plate riveted to it may have been replaced due to a fault or upgrade with the VIN plate mistakenly not transferred. It's not impossible, though, that a corroded or damaged chassis was illegally replaced with a second hand chassis without a VIC (s/h can be legal without a new VIN and Q-plate subject to VOSA/DVLA VIC and approval) and chassis number re-stamp.
Hopefully, you checked the vehicle history and got a check done before purchase to ensure it wasn't a "bistsa", wringer or serious write-off.
www.nickslandrover.co.uk - You don't have to suffer in a Series!
#5 jad
jad
    Newbie
  • Settled In
  • PipPipPip
  • 768 posts
Posted 02 June 2011 - 05:21 PM
I got one of those but all my numbers were the same, so I believe the MOT man must have entered it wrong somewhere....
 ̶9̶̶0̶ ̶2̶̶0̶̶0̶̶t̶̶d̶̶i̶ ̶t̶̶r̶̶u̶̶c̶̶k̶ ̶c̶̶a̶̶b̶ ̶a̶̶l̶̶w̶̶a̶̶y̶̶s̶ ̶n̶̶e̶̶e̶̶d̶̶s̶ ̶w̶̶o̶̶r̶̶k̶̶.̶̶.̶̶.̶̶.̶̶.̶ ̶N̶̶o̶̶w̶ ̶R̶̶e̶̶b̶̶u̶̶i̶̶l̶̶t̶ ̶  Sold to fund a TVR :ph34r:
1978 Series 3 109 1UZFE project..... Soren's prediction: like an uncontrollable leafsprung rocket ship :D (which is pretty cool)
#6 western
western
    Recovery Man
  • Moderators
  • 31,078 posts
Posted 02 June 2011 - 05:23 PM
VIN Checker here
Ralph, M3WRM, MSA Recovery Operator -- Western Recovery [Motorsport] http://www.amro.org.uk/
Defender Forum Moderator
Keep LR4x4.com Independent -- you can help by Clicking Here
#7 Disco-Ron
Disco-Ron
    Old Hand
  • Settled In
  • PipPipPip
  • 1,205 posts
Posted 02 June 2011 - 08:45 PM
Tris, its easy enough to check the chassis number, it'd be stamped on the bracket that added to the fornt of the chassis that the jack fits into, drivers side, on the outer side.... if thats makes sense...... a quick wire brush and you should be able to check it...
#8 western
western
    Recovery Man
  • Moderators
  • 31,078 posts
Posted 02 June 2011 - 09:24 PM
he's already checked :D
Tris -- But the number stamped on the chassis dumb iron matches the V5
#9 CwazyWabbit
CwazyWabbit
    is tired.
  • 6,661 posts
Posted 03 June 2011 - 08:31 AM
Did you just get a letter? Or was there some kind of follow up? Might help the OP to know what he can expect to happen next
110 Station Wagon 300tdi.
#10 Tris Cocks
Tris Cocks
    Old Hand
  • Settled In
  • PipPipPip
  • 272 posts
Posted 03 June 2011 - 09:54 AM
Thanks for the response guys,
The two numbers ive got are as follows;
V5 and Chassis No - SALLDVA67WA156162
MOT and VIN Plate - SALLDVB67VA125955
Both of which say that its from a defender althought one is 1997 and the other 1998, guessi'll just have to see who comes knocking at the door :ph34r:
#11 Gromit
Gromit
    Old Hand
  • Settled In
  • PipPipPip
  • 1,616 posts
Posted 03 June 2011 - 10:02 AM
The 7th digit is the body type, so the first one 'A' is Truck Cab, Soft Top or Hard Top (Utility body) and the second one 'B' is 3 door Station Wagon, or Freelander 5 door hardtop.
As you've said, the 10th digit is the year.
Gromit
A big white TD5 110.
Check out my video. There's a Land Rover in it!
#12 CwazyWabbit
CwazyWabbit
    is tired.
  • 6,661 posts
Posted 03 June 2011 - 10:06 AM
Something doesn't look so good as your profile says you have a 90 CSW which would make the chassis number look to be the wrong one. :-(
Although it is possible that it was a truck cab and they stuck the whole CSW body onto it (forgetting to change the VIN plate).
Which would be legal apart from forgetting to change the vin plate.
#13 Les Henson
Les Henson
  • Supporters
  • 12,930 posts
Posted 03 June 2011 - 11:02 AM
Go with the V5 and chassis - could save you going to jail :)
Les.
#14 Gromit
Gromit
    Old Hand
  • Settled In
  • PipPipPip
  • 1,616 posts
Posted 03 June 2011 - 11:13 AM
The 8th digit should be an 'F' for 200 Tdi & 300 Tdi (2.5 Liter, 4 cylinder, Turbor Diesels) rather than the '6' that it is. :huh:
Gromit
#15 western
western
    Recovery Man
  • Moderators
  • 31,078 posts
Posted 03 June 2011 - 03:47 PM
V5 & Chassis VIN decodes as in here
MOT & VIN plate decodes as in here
Chaasis stamped number is the original identity, the body has no affect, just a location to mount the VIN plate.
#16 jad
jad
    Newbie
  • Settled In
  • PipPipPip
  • 768 posts
Posted 05 June 2011 - 06:27 PM
I just got a letter, sent it back and never heard anything since, that was about a year and a half ago now....
#17 western
western
    Recovery Man
  • Moderators
  • 31,078 posts
Posted 05 June 2011 - 06:50 PM
only if it does not have a cataylitic converter fitted
F = 2.5L, inline 4 cylinder, turbo-diesel (200Tdi/300Tdi) non EGR/cat, 11L or 16L
6 = 2.5L, inline 4 cylinder, turbo-diesel (200Tdi/300Tdi) EGR/cat
#18 CwazyWabbit
CwazyWabbit
    is tired.
  • 6,661 posts
Posted 05 June 2011 - 07:23 PM
So if he changes his vin plate to match his chassis number and sends them a letter all might be over.
#19 Les Henson
Les Henson
  • Supporters
  • 12,930 posts
Posted 05 June 2011 - 08:38 PM
Just say that the vin plate was on a second hand item that had been fitted and that the chassis No is the original.
Les.
