TDI Performance Parts?
ajh
Does anyone do real performance parts for TDIs? I know about the turbo options, but how about things like:
http://www.4wheelparts.com/Performance-Parts/BD-Diesel-VE-Pump-Performance-Pin-And-Spring-Kit.aspx?t_c=74&t_s=368&t_pt=6185&t_pl=102028
Or things like more complex curve aneroid eccentric pin profiles rather than the simple flat profile ones?
Depends on what your trying to acheave.. All out power or more driveability?
In standard form the TDi can be tuned (have more fuel dumped in) with ease, a bigger intercooler will help but increase lag, a bigger turbo will help but will give more lag. a VNT will not aid much with all out power but will give you more drivability..
Then you can get your injector pump faffed with so that the engine is well capable of putting its cylinder head into orbit...
^^ powerful and lowered? something
, i don't care what anyone says, including the pope, i want one! :blush:
what about just a simple fuel pump and turbo tweak? ;) or here are a few places that gives landy' some more power.
http://turner-engine...o.uk/index.html
http://www.automotiv....com/index.html
http://portal.jeengi...esel-tunes.html
http://www.twistedperformance.co.uk/
give them a phone, see what they advise you should change, tweak or upgrade? hope this helps. :)
If i pull away on gravel, i too can make my 200tdi spin the wheels. :rolleyes: If i put my foot on the accelerator, i can also make it chuck out black smoke. Both of my headlights work though. :ph34r:
I put the best part of 4k into my old 300tdi, pump, injectors, ported and polished head, turbo. And the best it made on a dyno was 182hp.
It eventually threw a rod after about 7 years of abuse.
What did you do for a intercooler to achieve this power?
Daan
no way you can get 195hp for a TDI. most struggle to get more than 160.. and then they can get unreliable. im quite happy with my estimated 145.
i had my previous 90 @ 160 & it was nice & reliable at that, yeh it smoked a bit but didnt break,
& i know of a tomcat with a 200+ tdi in it, it however does smoke quite a bit
