Help!! Bulkhead water leak (hole in bulkhead)
  • Please log in to reply
23 replies to this topic
#1 nitrotom93
nitrotom93
    Member
  • Settled In
  • PipPip
  • 38 posts
Posted 10 July 2012 - 01:08 PM
So with all this rain i thought it would be a good time to look for the water leak that seems to be puddling in the passenger footwell.
i removed the lower part of the dash where the wiper motor is to find this.. :unsure:
Posted Image
Posted Image
Wish i hadn't now!
You can see it goes through to under the bonnet.. also looks like the previous owner has tried to repair it
Whats the best way of repairing this? Im i best getting a welder out to patch this?
Thanks
#2 Maverik
Maverik
    In constant need of Instant Mechanical Gratification!
  • Supporters
  • 4,010 posts
Posted 10 July 2012 - 01:19 PM
I can see why that would cause a bit of a leak.... - best way to repair like you said is to insert a new piece of steel and weld it in, all other options would be a bit bodge/temporary. Quite a wee fundimetal problem you got there...
Mav
#3 Gazzar
Gazzar
    Old Hand
  • Settled In
  • PipPipPip
  • 1,465 posts
  • Location:The Royal Forest of Dean. With gearbox oil dripping on me.
Posted 10 July 2012 - 02:32 PM
Seen, and fixed this before - do you have a leak between the windscreen and the bulkhead? The one I repaired had the top of the bulkhead gone as well - I had to lift the windscreen + roof to repair. What's the outside like?
G.
#4 nitrotom93
nitrotom93
    Member
  • Settled In
  • PipPip
  • 38 posts
Posted 10 July 2012 - 03:46 PM
This is a photo from under the bonnet next to the heater box, can't really see it here though
Posted Image
and then this is just the outside
Posted Image
There is a crack running just under the gutter piece, it could do with the repair sections on these, how much would a garage charge for that?
Ive just been quoted £150 to patch the hole, does this sound reasonable? Sorry, its the first time ill have had welding done on it!
Ive also tightened the top bolt of the fake hinge as there was a gap behind it and sealed it, hope fully this will also reduce the leaks
Thanks
#5 Gazzar
Gazzar
    Old Hand
  • Settled In
  • PipPipPip
  • 1,465 posts
Posted 10 July 2012 - 04:20 PM
Difficult to see with just a photo but it looks like there could be allsorts going on there, in-board of the vent hinge looks too good. Of course it could just be a wet bulkhead.
At best it's just the fold of the bulkhead, so strip heater away, ditto wiper motor and patch.
At worst the bulkhead is quite rotten around the vent and under the screen, so the screen will have to be removed (implying the roof comes of), and a new corner welded in.
It could be anything in between those extremes, though for the bulkhead to rot where it has would lead me to think it's going to be worse, rather than better.
Again, from a photo it is difficult to say 100%.
Oh, and I don't think that the hinge is fake, the screen really CAN hinge forward! And the crack between screen and bulkhead is most likely a deteriorated seal, a bodge repair would be to use a gutter sealant on there - ensuring, of course, that you don't use silicone.
G.
#6 Maverik
Maverik
  • Supporters
  • 4,010 posts
Posted 11 July 2012 - 09:08 AM
Getting garage quotes for welding will cost a lot of cash, just make sure it is lump sum (if they'll even do that! - I would think not...) welding is very time consuming the cash is all man hours as apposed to actual materials. - the problem with the tin worm as its always a little worse than you think, until you have the whole area stripped and checked. its very difficult to weld to a thin rusty surface so you have to cut back to good steel to effectivly make a good repair... costs will rack up if you;re not carefull... in the mean time it could be cheaper to put another bulkhead in it...
I'd take this as a perfect excuse to learn how to weld ;)
#7 Steve King
Steve King
    Weekend Forest Dweller
  • Long Term Supporters
  • 765 posts
Posted 11 July 2012 - 11:28 AM
I know of a certain company in Somerset selling secondhand Land Rovers and when faced with corrosion of this sort, simply pop rivet a bit of chequer plate over it!! :blink:
#8 nitrotom93
nitrotom93
    Member
  • Settled In
  • PipPip
  • 38 posts
Posted 11 July 2012 - 04:50 PM
Stripped the rest of the dash of now, the other side isn't as bad but has already been plated by someone else
Posted Image
Posted Image
Been to the where i normally get stuff done for my car and he reckons you wouldn't be able to plate it and it needs a new bulkhead, or he said he could bodge it using fiberfill i think it was called.
Thanks
#9 mcc1979ian
mcc1979ian
    Apprentice furtive Megasquirter
  • 501 posts
Posted 11 July 2012 - 06:27 PM
looking at that id be very tempted to replace the bulkhead
1985 Landrover 90 4.6V8 (mid-rebuild)
2003 Landrover Discovery TD5
Anything for an easy life!! Oh **** i bought a Landy!!
#10 Maverik
Maverik
  • Supporters
  • 4,010 posts
Posted 12 July 2012 - 07:24 AM
It is repairable, but you will have to remove all the bits on eaither side of the bulkhead and surrounding area's... might just be better to get a replacment bulkhead/get that one fixed and sell it on to get some of your money back. I've still got my old bulkhead in "storage" need to get around to fixing it and I'll proabbly sell it on for that same reason.
Either way its going to be an expensive job for a garage me think - especially if they aren;t a land rover specialist.
#11 iomlt
iomlt
    Old Hand
  • Settled In
  • PipPipPip
  • 520 posts
Posted 12 July 2012 - 08:07 AM
agree, with the rest of the bulk head looking like that i'd be not worrying about it and wasting time / money on that look out for a new one. depending on the rest of the truck
#12 nitrotom93
nitrotom93
    Member
  • Settled In
  • PipPip
  • 38 posts
Posted 12 July 2012 - 06:21 PM
Well the rest of its in pretty good condition! Been resprayed at some point and the chassis and cross members are all good. It is a land rover specialist but i know a garage would charge a fortune and i know its a major job but how hard is it actually to do myself?
Trouble is that in september i will hopefully be going to uni so its not going to be driven very much until I'm back home so doesn't seem much point in replacing it now.
I was thinking instead of paying someone to weld it i may try "bodging" it for now (I know a lot of you wont be pleased!) and try plating it myself and then if i don't get in to uni or after it i'll then think about replacing it.
#13 Maverik
Maverik
  • Supporters
  • 4,010 posts
Posted 12 July 2012 - 08:10 PM
Hmm i see what you're saying, do you know anyone that can weld? - tbh bodging it would probably just as tricky... you;re still going to have to strip a fair amount off, if its already stripped can you find someone to weld it for you, I would!!! but I;m a little far away.
#14 nitrotom93
nitrotom93
    Member
  • Settled In
  • PipPip
  • 38 posts
Posted 12 July 2012 - 09:04 PM
just a little bit too far! yeah i have a friend who's building a steel tube framed off road buggy so he's going to have a go at welding it for me.
Stripping it isn't really a problem, i have plenty of time on my hands now I'm on summer holiday! :i-m_so_happy:Its giving me something to do for the next couple of weeks before i start working!
#15 CwazyWabbit
CwazyWabbit
    is tired.
  • 6,661 posts
Posted 12 July 2012 - 09:56 PM
Pop some piccies up of the work being done if you can, we like a bit of a post mortem .... we're gory like that ;) It's also nice to see the rescued product, gives us all motivation :)
110 Station Wagon 300tdi.
#16 nitrotom93
nitrotom93
    Member
  • Settled In
  • PipPip
  • 38 posts
Posted 12 July 2012 - 10:32 PM
Well the whole dash is already stripped, and looking very dirty behind there... Whilst its all off I thought it might be a good idea to sound proof behind the dash as its much louder with no dash! ( I suppose the hole isn't really helping!) has anyone done this? I problem I can see of it needs to be very thin so the dash still fits properly.
Going to attempt to weld on Monday now I think
#17 mcc1979ian
mcc1979ian
  • 501 posts
Posted 13 July 2012 - 07:55 AM
just soundproofed mine with rattlemat, id say its 2 - 3 mm thick and the dash still fits great, looking at it, it could probably have been thicker, just make sure to leave the areas where the dash bolts/screws up flush to the bulkhead and you will be ok.
http://www.ebay.co.u...984.m1439.l2649
#18 CwazyWabbit
CwazyWabbit
    is tired.
  • 6,661 posts
Posted 13 July 2012 - 10:12 AM
£500 a roll!!!! What is it? Gold leaf? :blink:
#19 nitrotom93
nitrotom93
    Member
  • Settled In
  • PipPip
  • 38 posts
Posted 13 July 2012 - 11:29 AM
Bit out my price range that! :blink: Although looking at it in different sizes its much more reasonable so I'm guessing thats just an error.
Did it make much of a difference? And is that how much you needed to do it all?
#20 mcc1979ian
mcc1979ian
  • 501 posts
Posted 13 July 2012 - 12:58 PM
wow, i must of got discount :hysterical:
its £22.99 for the 300mm x 5m roll, if you look further down the page its in the description, obviously theres some problem with the buy it now price listed now.
Not sure if its made a difference yet as iv not finished rebuilding the 90 but im gone do the doors, roof, and front of the rear bulkhead too, i may need one more pack to finish it but will probably end up with loads spare,
i reckon if you could get a 300mm x 1.5m roll that would be more than sufficient for your bulkhead.
