Straightening a dented door...
  • Please log in to reply
12 replies to this topic
#1 Big.Mike
Big.Mike
    Advanced Chicken Juggler
  • Long Term Supporters
  • 758 posts
Posted 24 September 2012 - 01:51 PM
My 110 CSW has a very dented rear door, it's around the handle and is so bad that there is a 5mm gap around the top. The handle took the brunt of the impact which cracked in two.two.
My question is, is there an easy way to straighten this, if so how? I'm tempted to take the door card off and hit it with a lump of wood from inside, trying not to break the glass.
My gut is telling me to get a new door, but I like that it has a few battle scars... I just want it to function as a door.
Cheers,
MikeMike
Mike: "Lily" - Defender 130 - 300TDi- County Station Wagon - TDCi seats - WIP
 "Daisy" - Defender 110 - 300tdi, daily drive.
"Molly" - 101 GS with an aluminum back end.
#2 CwazyWabbit
CwazyWabbit
    is tired.
  • 6,684 posts
Posted 24 September 2012 - 02:24 PM
Do you mean one of the second row doors? Or the actual back door (I only ask as I don't see how the handle on the back door would break).
I had my passenger door dented quite badly when some drugged up idiot threw a shopping trolley into it last new years eve. I've managed to get most of the dent out but it is by no means perfect. The steel frame reinforces the door in the area you are speaking of (assuming I'm on about the right door :) ) and this is glued to the aluminium skin. I ended up cutting the glue and straigtening the skin as best I could then straightening the reinforcing. I then reglued the skin to the frame using sikaflex and clamped a bit of wood across the door to keep the skin flat till it dried.
Not sure if what I've said is any help in your situation.
Before
Attached File  Door before.jpg   167.38KB   68 downloads
After
Attached File  Door After.jpg   165.23KB   67 downloads
110 Station Wagon 300tdi.
#3 steve200TDi
steve200TDi
    ...not 90 not a 200TDi now its a TDious 5
  • Settled In
  • PipPipPip
  • 1,001 posts
Posted 24 September 2012 - 02:29 PM
Hello fellow member from the Horsham area!
If you have a picture then we could make a decision. It sounds like with a bit of panel beating then it could be made servicable again.
It does sound like it's the passenger rear door, not the back door. I have (A tree has) pushed my door handle into my door twice now and I have successfully pushed it back out again with a bit of panel beating here and there to regain it's former shape.
I am now doing to one piece lift up handle doors to hopefully cure the problem!
Steve
Land Rover defender TD5 90, Build thread: http://forums.lr4x4....showtopic=76471
#4 Big.Mike
Big.Mike
  • 758 posts
Posted 25 September 2012 - 12:46 PM
@steve200TDi thanks for the Horsham greeting.
Sorry I should have been clearer: the passenger offside second row door ;)
Problem 1: Fixed, I put a 4x2 in the door and pushed on the top to bend it back into shape, then I moved the hinges to fit, gap gone. :rolleyes:
Problem 2: Dent is right behind the handle (I suspect caused by the handle) I'm tempted to drill a hole in the door skin and use a hook to put the panel out, I have lots of plugs to fill the hole.
Attached File  20120820_195014 2.jpg   61.66KB   51 downloads
Any thoughts?
Cheers,
Mike
#5 CwazyWabbit
CwazyWabbit
    is tired.
  • 6,684 posts
Posted 25 September 2012 - 12:49 PM
Can you not just remove the handle and stick a hook of some description through the hole left by removing the handle?
#6 GW8IZR
GW8IZR
    Mild Overindugence sufferer
  • Supporters
  • 858 posts
Posted 25 September 2012 - 05:02 PM
Glue stick might work
HTH
Regards Paul
#7 steve200TDi
steve200TDi
  • Settled In
  • PipPipPip
  • 1,001 posts
Posted 25 September 2012 - 05:37 PM
I would remove door card, window mechanism and handle and using a variety of small hammers and drift slowly work it back into shape.
Steve
#8 Big.Mike
Big.Mike
  • 758 posts
Posted 25 September 2012 - 08:52 PM
Steve
It doesn't look as bad in the photo as it actually is; the entire door has taken a hit.
I'll give the drifting a try, but I actually suspect I might have more luck getting the door on a flat surface and hitting it with a lump of wood!
#9 CwazyWabbit
CwazyWabbit
    is tired.
  • 6,684 posts
Posted 25 September 2012 - 09:51 PM
It doesn't look as bad in the photo as it actually is.......
I don't know, from the reflection it looks like you were taking pictures in your dressing gown in the afternoon..... I'd say that looks bad :P
Seriously though, it is amazing how well photos seem to play down dents, if you take the picture looking along the door they tend to show up better ;) If you go the lump of wood route it's easy to over do it and make it harder to repair, it's easy to crease the aluminium by catching a corner of the wood or steel frame.
#10 mmgemini
mmgemini
    Old Hand
  • Settled In
  • PipPipPip
  • 4,407 posts
Posted 26 September 2012 - 10:09 AM
Use a sandbag on the outside of the door. Rubber hammer or a lump of wood to knock it out from the inside.
mike
Quis custodiet ipsos custodes?
I can cause trouble in an empty house !
#11 Gazzar
Gazzar
    Old Hand
  • Settled In
  • PipPipPip
  • 1,468 posts
  • Location:The Royal Forest of Dean. With gearbox oil dripping on me.
Posted 26 September 2012 - 03:37 PM
Apply gentle heat too, you might save the paint from flaking!
#12 muddy
muddy
    Old Hand
  • Supporters
  • 1,950 posts
Posted 29 September 2012 - 08:19 PM
I'd get a my favorite hammer and add some more dents throughout the vehicle just to even it up :P
MMMMMMM Heavy duty........
#13 Big.Mike
Big.Mike
  • 758 posts
Posted 30 September 2012 - 04:54 PM
Ha! Daisy is already reasonably dented. I don't mind the dents, in fact I go on the same principle as some photographers; the more abused she looks the less attention she'll attract.
The only caveat to this is that the dent's don't affect the water-tightness or function of Daisy. Unfortunately both are affected at the moment.
Cheers,
Mike
