Very Strange Electrical Fault
  • Please log in to reply
7 replies to this topic
#1 mcc1979ian
mcc1979ian
    Apprentice furtive Megasquirter
  • Long Term Supporters
  • 548 posts
Posted 29 September 2012 - 04:59 PM
Ok so the past few weeks iv had trouble wi the freelanders battery and in the end it turned out to be the alternator. So after fitting a new one i discovered my battery charger had seen better days so had to jump the freelender off the disco. Now since doing this my sidelights on the disco have been coming on when i start it, then came home in the dark one night, took the key out but had forgot to switch the lights off but strangely the engine was still running. Very strange, so turned the lights off and the engine stopped. Now the other one is the fuse had blown for the fuel gauge, temperature gauge and rev counter so replaced this and now these all work again but iv still got the other fault with the lights and engine running.
Iv tried all the fuses and all are ok.
Iv disconected every light on the vehicle and it still dosent solve the problem.
Have checked all the earths and all look good.
Changed the battery for a spare i have and still no change.
Please can someone solve this problem as its got me at the end of my wit.
p.s if someone can i will love you forever......................... :wub:
1985 Landrover 90 4.6V8 (mid-rebuild)
2003 Landrover Discovery TD5
Anything for an easy life!! Oh **** i bought a Landy!!
#2 Gazzar
Gazzar
    Old Hand
  • Settled In
  • PipPipPip
  • 1,506 posts
  • Location:The Royal Forest of Dean. With gearbox oil dripping on me.
Posted 29 September 2012 - 06:14 PM
Well, with a landrover the first thing to check is the Earths!
#3 mcc1979ian
mcc1979ian
  • 548 posts
Posted 29 September 2012 - 06:45 PM
Checked them, they all look ok.
#4 simonr
simonr
    Trainee shepherd
  • Supporters
  • 5,731 posts
Posted 29 September 2012 - 09:22 PM
The symptoms you describe are indicate an earth fault. You may not have found it yet, but I would bet that's the problem!
Si
#5 JasonG4110
JasonG4110
    Sankey Trailer expert!!
  • 2,354 posts
Posted 29 September 2012 - 09:49 PM
Might sound strange but how did you jump it? If you connected it to an earth that was not up to the job you could have melted or damaged that earth supply internally without realising it.
Jason.
If brute force, tie wraps or duck tape won't solve your problems, then you aren't using enough!!
2010 Freelander 2, 2003 110 G4 LE,
#6 mmgemini
mmgemini
    Old Hand
  • Settled In
  • PipPipPip
  • 4,414 posts
Posted 30 September 2012 - 07:24 AM
That's an eart problem.
Start with the battery negative and work through from there.
mike
Quis custodiet ipsos custodes?
I can cause trouble in an empty house !
#7 HoSS
HoSS
    Old Hand
  • Supporters
  • 1,083 posts
Posted 30 September 2012 - 01:49 PM
sounds to me like a short between 2 cicuits, possibly in the fuse box or loom. Are the fuel pump (or whatever makes the engine run) and the lights fuses next to each other?
If nothing that we do matters, then all that matters is what we do.
#8 mcc1979ian
mcc1979ian
  • 548 posts
Posted 30 September 2012 - 03:49 PM
Jason.
positive to positive and negative to neagative, have done it many ways this time without a problem.
Will get back to it when i get some spare time and see if i can solve it.
