300tdi overheated now wont start next day
  • Please log in to reply
7 replies to this topic
#1 indoken
indoken
    Newbie
  • New Faces
  • Pip
  • 13 posts
Posted 01 October 2012 - 03:07 PM
hi
help needed
yesterday i was driving my 300tdi when i lost all coolant and overheated badly. managed to limp home stopping to refill water every 2 miles. the expansion tank had split so i have got a replacement. now however the engine tries but fails to start. lots of smoke comming out the back that looks like unburned fuel but no firing. could this be a symtom of a warped head/blown gasket.
thanks.
ken
#2 BogMonster
BogMonster
    Old Hand
  • Moderators
  • 12,163 posts
  • Location:Third rock from the Antarctic - 5141.8'S 5750.5'W
Posted 01 October 2012 - 05:01 PM
Or massive horrible bore wear - pistons picking up on the bores - v expensif :(
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Mitsubishi Shogun SG2
#3 Puffernutter
Puffernutter
    Newbie
  • Long Term Supporters
  • 541 posts
Posted 01 October 2012 - 05:06 PM
When mine overheated I burnt through a piston!
Cheers
Peter
1997 LDV Convoy LWB HiTop (Dog Van), P38 Mk2 (my gas guzzler!)
1972 Triumph Stag (almost on the road), 1968 Rover P5B Coupe, 1964 Rover P4 110 (Basket case!)
1974 Stag - On the road! - I love V8s!
#4 steve b
steve b
    Old Hand
  • Settled In
  • PipPipPip
  • 1,686 posts
Posted 01 October 2012 - 05:31 PM
Hi
I'd pull either the heater plugs or injectors and crank it over to see if you have water where it shouldn't be - it'll squirt out when you crank it so look out
If so it is possible to bend a conrod just trying to start it so head off and check it all
An initial test would be to pressure the water system 10 - 12 psi and see if the pressure stays (good) or drops (bad)
hth
Steveb
portal - a doorway to a different world
#5 indoken
indoken
    Newbie
  • New Faces
  • Pip
  • 13 posts
Posted 01 October 2012 - 08:25 PM
hi
the head is now off. it was the gasket between pots 2/3. luckily there was a partial seal around the pistons so i was loosing compression but no water was getting into the pots.
thanks for the suggestions
ken
#6 matt bristol
matt bristol
    Newbie
  • Supporters
  • 165 posts
Posted 01 October 2012 - 08:56 PM
Its F'ed anyway so if it was me I would pull the head off and have a look - if the bottom end is OK you will need to change the head gasket and either replace the head or skim, if the bottom end is dead its lighter to get out
#7 Puffernutter
Puffernutter
    Newbie
  • 541 posts
Posted 02 October 2012 - 10:59 AM
Glad to hear it wasn't as catastrophic as mine!
Good luck when it's all back together. I ended up fitting a RR expansion tank with a level sensor in it so it wouldn't happen to me again, or if it did, I would know about it quicker.
In the end it turned out that I had a leak on the heater matrix and that was causing the water loss. That was a major pain to change....
Cheers
Peter
#8 indoken
indoken
    Newbie
  • New Faces
  • Pip
  • 13 posts
Posted 02 October 2012 - 06:32 PM
hi
oh well thats me £500 lighter. new head, new water pump...............+ other parts
thats what i call a s***t day
ken
