reb78 Posted October 22, 2012 Share Posted October 22, 2012 Anyone got any ideas where i can get a pipe reducer that goes from 16mm to 4mm and is also suitable for diesel? Or, will i have to do this using a couple of reducers? Its so i can convert an expansion tank to a diesel tank for my eberspacher whilst i have SVO in the main tank. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted October 22, 2012 Share Posted October 22, 2012 something like this?? http://www.ebay.co.uk/itm/6mm-4mm-BARBED-PLASTIC-STRAIGHT-HOSE-REDUCER-CONNECTOR-FUEL-PIPE-JOINER-REPAIR-/380423461474?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5893015a62 Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 22, 2012 Author Share Posted October 22, 2012 something like this?? http://www.ebay.co.u...=item5893015a62 Yep, but can i go from 16mm to 4mm in one go? Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted October 22, 2012 Share Posted October 22, 2012 Yep, but can i go from 16mm to 4mm in one go? sorry, thats my fault! typo when i searched it. could you not lathe one out of brass? that should be very easy, even for me! or you may need a few reducers connected together?.. Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 22, 2012 Author Share Posted October 22, 2012 sorry, thats my fault! typo when i searched it. could you not lathe one out of brass? that should be very easy, even for me! Good idea. I havent got a lathe, but i'm sure i know someone who has one..... Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted October 23, 2012 Share Posted October 23, 2012 Good idea. I havent got a lathe, but i'm sure i know someone who has one..... i've got a nice lathe.. And tons of metal..... Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 23, 2012 Author Share Posted October 23, 2012 i've got a nice lathe.. And tons of metal..... I was hoping you might say that...... Would you be able to knock something up Dave? I was planning on using some old coolant hose to join the 16mm section to the bottom fo the expansion tank - will it cope with diesel (if i have the reducer close to/touching the bottom of the tank outlet, then there would be minimal exposure of the pipe to the fuel). I wish i had a lathe - reckon it would be a great tool to have use of. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted October 23, 2012 Share Posted October 23, 2012 ...... I wish i had a lathe - reckon it would be a great tool to have use of. They are, but it does take a while to get reasonable results from when you first start. The likes of VB will be able to knock something up in their sleep but for those of us back garden machinists it takes a little more practice Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 23, 2012 Author Share Posted October 23, 2012 They are, but it does take a while to get reasonable results from when you first start. The likes of VB will be able to knock something up in their sleep but for those of us back garden machinists it takes a little more practice Learning to use it well is half the fun. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 23, 2012 Share Posted October 23, 2012 The likes of Hyphose or Pirtek should be abvle to sell you the thingy if it exists, or invent/spin one up to suit if not. They do those plastic ones but also brass ones. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted October 23, 2012 Share Posted October 23, 2012 I was hoping you might say that...... Would you be able to knock something up Dave? I was planning on using some old coolant hose to join the 16mm section to the bottom fo the expansion tank - will it cope with diesel (if i have the reducer close to/touching the bottom of the tank outlet, then there would be minimal exposure of the pipe to the fuel). I wish i had a lathe - reckon it would be a great tool to have use of. Piece of cake! Lathes arnt that exciting to have (well not to me anyway) but handy if you know someone with access to one or 9 like me. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted October 23, 2012 Share Posted October 23, 2012 could you not lathe one out of brass? <pedant mode> While one mills with a milling machine, one turns with a lathe </pedant mode> But good suggestion though Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted October 23, 2012 Share Posted October 23, 2012 <pedant mode> While one mills with a milling machine, one turns with a lathe </pedant mode> But good suggestion though you knew what i meant! but cheers for the correction tho. Quote Link to comment Share on other sites More sharing options...
