LR4x4 - The Land Rover Forum: 300TDI cylinder head removal - LR4x4 - The Land Rover Forum
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
300TDI cylinder head removal By Les Henson none the less
#1 User is offline   white90
  • Treasurer
  • PipPipPipPip
  • View gallery
  • Group: Admin
Posted 18 September 2006 - 09:32 AM
No great mechanical skills needed to do this, you do need a torque wrench though if you plan to put the head back on. The cylinder head is alloy, so not a heavy great thing like the series and 2.5N/A and TD engines. It's relatively easy to remove the head and replace it. Taking what seems to be half the engine apart may appear daunting, but it takes less than two hours to remove it. Timing of the engine is not affected, nor are the electrics. The injector pipes have to be removed, and the glow plugs disconnected, but this is all minor stuff.
The engine in this thread is in a Disco that cooked the engine rather badly. The head has been removed to inspect engine damage, which is covered in a different thread.
If you are looking at the following pictures as a reference as you work on your own engine, then the radiator is out, top intercooler hose, top radiator hose, front heater hose, alternator wiring, the black engine cover, and other not necessarily associated other items have already been removed.
The reasons for removing the head can be varied - from replacing the head gasket, part of an engine rebuild, valve re-grind, Les Brock trying to get it right for the 3rd time :P .
Starting point. The engine is mostly complete as far as cylinder head removal is concerned.
Disconnect the battery.
Posted Image
Injector pipes first. They are fixed together in pairs - 1+2, 3+4. It's easier to remove 3+4 first as it then makes it easier to undo 1+2 where they are connected to the rear of the injector pump. Undo all 4 pipes where they connect to the injectors with a 17mm spanner. Take care not to snap the top of the injectors.
with the same size spanner, undo 3+4 and remove, then 1+2.
Once the pipes are removed, undo the two jubilee clips (6mm), and remove the two pipes from the oil seperator, and then undo the single 8mm bolt that holds the seperator to the side of the rocker cover. It's common for the seperator to leak, and as such is likely to be stuck on with RTV sealant. This is plastic, so be careful not to snap it.
Posted Image
Posted Image
Disconnect the power supply to the glow plugs (black cable), then remove the other 3x7mm nuts to remove the wiring loom for the glow plugs (yellow wire). Put the nuts and washers back on the glow plugs to prevent losing them.
Posted Image
Undo the two jubilee clips that hold the balance pipe and remove it completely. The spill rail pipe is melted in this picture, but normally you would undo the banjo bolt at it's end on the back of the injector pump (17mm). Put the bolt back in it's hole along with the two copper sealing washers.
Posted Image
Thermostat wire is at the front of the engine close to the thermostat housing funnily enough :D . Just pull it off.
Posted Image
Two heater supply hoses at the back/top of the engine. Undo the clips and bend/tie them out of the way.
Posted Image
Remove thermostat to water pump bypass pipe completely as well.
Posted Image
Now to the passenger side of the engine - the inlet manifold is only held by 2 x 10mm head bolts that have to be removed completely, and 2 x 13mm head nuts that only need to be undone a few turns.
Posted Image
Posted Image
The inlet manifold will just lift up off of the bottom studs.
Remove the rest of the nuts (15mm) that hold the exhaust manifold onto the head - 2 at the top with a spanner, one hidden in the gap between the turbo and manifold, and two at either end.
Posted Image
Posted Image
The steel portion of the heater hose is held onto the top of the head by two of the exhaust manifold nuts.
Posted Image
Once all the nuts and bolts have been removed, there's enough slack in the exhaust to move it away from the engine. Don't use any force, as the turbo oil feed and drain pipe is still connected.
Posted Image
The inlet manifold - two long 10mm head bolts through the top holes, and the two 13mm nuts that only have to be undone to allow it to be lifted off.
Posted Image
All that's now holding the head on the engine is 18 bolts. Four on the drivers side.
Posted Image
Nine close to the manifolds.
Posted Image
Undo the 3x13mm acorn nuts that hold the rocker cover on, and remove it. There are 5-more head bolts inside.
Posted Image
Rocker assembly next. This is held to the head by 3x13mm nuts that are on the same thread that the acorn nuts were on, then 2 x 10mm head bolts. Once these are removed, the whole assembly lifts off as one.
Posted Image
There are then 8 pushrods that have to be lifted out. If you don't plan to re-set the tappets, then keep these in the order they came out.
Posted Image
Head bolts now. All are 19mm and quite tight. A breaker bar is handy to undo them, or at least break them from their threads. There is a tightening sequence when fitting the bolts, and you should use the same sequence to undo each bolt 1/2 turn until they are loose enough to be removed easily. There are also three different sizes of bolt, and two different threads. If you think that the bolts have been over-stressed or damaged, then consider replacing them.
Posted Image
Two of the head bolts cannot be removed while the engine is still in the vehicle - the scuttle panel prevents this. You therefore need to secure them out of the block, and the easiets way is to lift them out to within 15mm of the panel, and then tie them as shown. The slight angle they are in prevents them from dropping back down.
Posted Image
The head is now free, and will lift off. If it doesn't, then a small a mount of leverage in a safe place will do the job.
Posted Image
Les. :)
Tony
Keep this forum independent click HERE.
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
