transfer box wrong oil
  • Please log in to reply
9 replies to this topic
#1 brent 3045
brent 3045
    Member
  • Settled In
  • PipPip
  • 22 posts
Posted 22 March 2013 - 01:04 PM
I accidently put a litre of mtf oil in transfer box, will it cause any damage?
#2 reb78
reb78
    Old Hand
  • Supporters
  • 3,845 posts
Posted 22 March 2013 - 01:10 PM
Probably not. If you just put it in and let it stand, then no, but if you'd done 150k on it then maybe. Bit more info perhaps....??
If you are asking will it cause damage in the future, i.e. you are contemplating leaving it there, then i would advise to drain and re-fill with EP90.
Richard
1989 110 - Defender 200tdi (ex 19J), LT77s, LT230 (from a TD5) & GKN overdrive
2004 D2 TD5 Landmark
#3 brent 3045
brent 3045
    Member
  • Settled In
  • PipPip
  • 22 posts
Posted 22 March 2013 - 01:19 PM
Just topped up for offroading at weekend, will drain off and change before next time, maybe month. Thanks
#4 reb78
reb78
    Old Hand
  • Supporters
  • 3,845 posts
Posted 22 March 2013 - 01:41 PM
Should be fine then. They are pretty hardy boxes. Definately change it though.
Richard
#5 Jode
Jode
    Member
  • Settled In
  • PipPip
  • 115 posts
Posted 06 April 2013 - 06:33 PM
MTF is a 75W80 GL4 oil and should be fine for the LT230. Roamer Corp (makers of the formally named RoverDrive, name now changed thanks to Tata's legal department) insist on using synthetic GL4 gear oil, and advise that MTF is suitable.
#6 reb78
reb78
    Old Hand
  • Supporters
  • 3,845 posts
Posted 06 April 2013 - 10:27 PM
What about MTF94 - as used in the R380? Surely that would be too thin. Perhaps the OP needs to give more info on the exact type of oil used.
Richard
#7 V8 Freak
V8 Freak
    I'm not as thunk as drinkle peep I am....
  • Admin
  • 2,580 posts
Posted 06 April 2013 - 10:56 PM
But the Roverdrive peeps insist on fully synthetic because EP90 adversely affects some of the metals used in the overdrive...
I'm trusting them that there will be no adverse performance or life issues on my transfer box using the oil they specify and not that recommended for the LTL230!!!
Bonatti Grey Tedious 5 90 XS...... Diseasel !!!
#8 Snagger
Snagger
    Old Hand
  • Supporters
  • 3,355 posts
Posted 07 April 2013 - 07:49 AM
They advise the use of synthetic 75w90 because they don't get EP90 out there.  And it's not all EP90s that can damage the bronze-phosphor parts - it's just some of the GL5 specs, so you should still use EP90 GL4 where available.
www.nickslandrover.co.uk - You don't have to suffer in a Series!
#9 V8 Freak
V8 Freak
  • Admin
  • 2,580 posts
Posted 07 April 2013 - 10:55 AM
Thanks for the heads up Snagger.... I went Redline anyway for LT230 & Overdrive to make sure I was keeping to warranty requirements !
Neil
#10 Mo Murphy
Mo Murphy
    Broad Minded
  • Long Term Supporters
  • 6,778 posts
Posted 07 April 2013 - 01:05 PM
You can still buy straight 90 gearbox oil that doesn't affect phosphor bronze. Commonly used in Lambretta scooter gearboxes :)
Mo
The Land Rover 90: Many are called, few are chosen ...
Fifty Shades of Pennine grey
