LR4x4 - The Land Rover Forum: on board air all done - LR4x4 - The Land Rover Forum
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   SteveG
  • Old Hand
  • PipPipPip
  • Group: Settled In
  Posted 24 September 2006 - 06:55 PM
picked up a viair 100% duty air compressor, 450C complete with onboard air kit.
Fitted it earlier this week. took longer for me to do than expected. More down to finding right location and getting some extra fittings.
The compressor is dust and moisture resistant but not waterproof so I decided to fit it inside. I had an arb compressor in the back of the hybrid and found that it got in the way so this time I fitted it behind the drivers seat.
Posted Image
I also fitted the guage and on-off switch there too to keep all power cables as short as possible. The compressor draws max of 19A.
Posted Image
I located the tank under the drivers seat as the TD5 has it's fuel tank at the rear. I replaced the standard 6mm compression fitting with right angle push-on types. I find these easier to work on and the right angle put less strain on pipe.
Posted Image
It tucks up out of the way well, but I think I'll replace the drain plug with a blanking plug so that it doesn't get ripped off..
Posted Image
Having the guage nearby meant that wiring was simple. Unfortunately the lead hose fitted to compressor was not long enough to reach the tank so I got some 8mm push-on fittings and 8mm pipe to extend it..
Posted Image
I also fitted the female output fitting here too. This allows easy access via drivers door or I can also pull it through passenger door and reach both nearside tyres.
Posted Image
Again, keeping everthing in one place kept plumbing to short runs..
Posted Image
When I get a rear locker I'll change out combined pressure switch/relay to an 85-105 psi one. The current one is 150psi and it's a straight swap.
Cheers
Steve
#2 User is offline   JST
  • LRS Sanctuary
  • PipPipPipPip
  • Group: Settled In
Posted 24 September 2006 - 07:00 PM
Steve thats looks like a cracking job, well done very mneat and tidy certianyl not a JST affair!
i would consider something for the tank though and as you righly say the drain tap would benefit a change! incase it in some protection folded sheets etc.
whats the CFM on that then will it run an impact wrench?
#3 User is offline   landrover598
  • Old Hand
  • PipPipPip
  • Group: Settled In
Posted 24 September 2006 - 07:17 PM
Done a very tidy job there B) I bet it doesn't leak as much as my newly installed on board air system though :lol: :rolleyes:
David Lang
100" TDi Defender
#4 User is offline   SteveG
  • Old Hand
  • PipPipPip
  • Group: Settled In
Posted 24 September 2006 - 07:19 PM
CFM is 1.66 at 0psi and 0.72 at 150 psi. Wit the tank I would think that you could run an impact wrench on burst no problem. Personally I have had one of these for the past few years so I've had no need ;) ...
Posted Image
Cheers
Steve
#5 User is offline   simonr
  • Trainee shepherd
  • PipPipPip
  • View gallery
  • Group: Settled In
Posted 24 September 2006 - 07:30 PM
Well done Steve. When you come to fit lockers - why not leave your pressure switch as is and add a small in line regulator to regulate down to 85psi or so. That way you are getting an effective 50% increase in the capacity of your air tank and the reg will prob cost less than a new switch.
(that's what I've done incidentally)
Si
X-Eng 10% Discount on Own-Brand products for forum members -
Go in to my profile, and from there click on the profile link for my web site.
#6 User is offline   SteveG
  • Old Hand
  • PipPipPip
  • Group: Settled In
Posted 24 September 2006 - 07:48 PM
Si
Good idea Si, i'll source one of those then :)
Thanks
Steve
#7 User is offline   white90
  • Treasurer
  • PipPipPipPip
  • View gallery
  • Group: Admin
Posted 24 September 2006 - 08:47 PM
you could fit a TDI tank guard to protect the air reservoir
Tony
Keep this forum independent click HERE.
#8 User is offline   SteveG
  • Old Hand
  • PipPipPip
  • Group: Settled In
Posted 24 September 2006 - 09:29 PM
Once I fit the blank, I'm not sure it will need it but I'll have to see.
#9 User is offline   Les Brock
  • SVA Test Pilot
  • PipPipPip
  • Group: Settled In
Posted 24 September 2006 - 09:44 PM
Steve,
The tank will need draining quite regulary, mine have little push type valve, and its surpising how much condensate sits in the tank, a good eggcup full after a weekends use
not only will it rust your tank (eventually :rolleyes: ) but find its way into your tools/tyres etc
Lesmond
200Tdi Defender 100 Inch Trayback - Q Plate Old Knackered Disco
Work in Progress - Defender 200Tdi Auto on Galv Chassis
#10 User is offline   davidlandy
  • Member
  • PipPip
  • Group: Settled In
Posted 25 September 2006 - 08:19 PM
what about an ARB compressor, does this need emptying as well?
I have never done this with mine!
sniff sniff, this mud smells funny
Posted Image
#11 User is offline   white90
  • Treasurer
  • PipPipPipPip
  • View gallery
  • Group: Admin
Posted 26 September 2006 - 03:26 AM
I just release the air when not inuse that'll help keep condensation at bay
Tony
#12 User is offline   cols110
  • An Antipodean on walkabout
  • PipPipPip
  • Group: Settled In
Posted 26 September 2006 - 04:29 AM
Very nice mate, this is one of my next jobs on the list, where did you get all the gear, it is the same as Matt Savage sells.
The only thing that would worry me a little is the blue air line, it looks a bit small to allow max flow from the tank, especially when you want a high flow rate for blowing tyres etc, the in-side would be fine as it is more than big enough for the supply from the compressor, and for the gauge, but may restrict the flow from the tank.
Cols110
2002 TD5 110
2004 V8 Disco
Previous toys
1990 200TDI 110 Camel Trophy
1989 V8 110
#13 User is offline   Hybrid_From_Hell
  • For some odd reason now an avid collector of Autoboxes
  • PipPipPipPip
  • View gallery
  • Group: Moderators
Posted 26 September 2006 - 06:20 AM
Nice job Steve.
To proterct it quickly ands simply how about a early type southdown petrol tank guard ?
Nige
Want to Megasquirt your V8 ? - My Website : www.megasquirt-v8.co.uk - or PM me
This Signature doesn't imply approval by, or have any connection with www.LR4x4.com
Keep this forum independent click here
#14 User is offline   Tonk
  • and now its gone!
  • PipPipPip
  • Group: Settled In
Posted 26 September 2006 - 06:31 AM
was the reservoir part of the kit or did u source that separately?
TTRovers
Keep this forum independent click here.
#15 User is offline   SteveG
  • Old Hand
  • PipPipPip
  • Group: Settled In
Posted 26 September 2006 - 07:55 AM
Yes it is, for some reason the 1007 100% duty kit is a lot lower in price on website ;) only 24 pounds more than compressor on it's own :)
The 6mm tube should be ok as it's universally used for pneumatic applications, but it's easy to change fittings as I did. Just get 1/4 BSP fittings with either 8mm or 10mm pipes. 8 & 10 are used in workshops/factories to feed airlines around so must be ok for air tool applications.
Tonk yes tank came with kit, it's a 2.5 Gallon (US) tank.
Cheers
Steve
#16 User is offline   Tonk
  • and now its gone!
  • PipPipPip
  • Group: Settled In
Posted 26 September 2006 - 08:00 AM
i was just looking for ideas for a bigger reservoir and thought yours looked about the right size. do they do chrome ones? :D
TTRovers
#17 User is offline   SteveG
  • Old Hand
  • PipPipPip
  • Group: Settled In
Posted 26 September 2006 - 08:13 AM
I'm surprised they don't as they do chrome and pewter compressors!! :blink: The low riders in the US like these for their air suspension.
The tanks can be bought on their own and range from 25 pounds up to 67 for the 5 gallon one.
Cheers
Steve
#18 User is offline   Tonk
  • and now its gone!
  • PipPipPip
  • Group: Settled In
Posted 26 September 2006 - 08:18 AM
Cheers
Steve
ooo so they do, cheers ;)
TTRovers
#19 User is offline   white90
  • Treasurer
  • PipPipPipPip
  • View gallery
  • Group: Admin
Posted 28 September 2006 - 11:47 PM
would a small airless compressor run from an inverter be another possible option?
Tony
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
