PRC4427 Voltage Sensitive switch
  • Please log in to reply
5 replies to this topic
#1 Maverik
Maverik
    In constant need of Instant Mechanical Gratification!
  • Supporters
  • 4,079 posts
Posted 21 October 2013 - 02:40 PM
Another mystery to me while stripping the 89, LR110.
There was the big yellow relay PRC4427 floating around behind the dials when I took it apart, there are a lot of fine brown/black wires going into the relay base.
Can anyone tell me what the relay was for?
I thought you only needed them in a split charge system, said vehicle has only one set of battery cables and no other signs of a split charge system...
Mav
#2 ChrisB
ChrisB
    Member
  • Settled In
  • PipPip
  • 104 posts
Posted 21 October 2013 - 03:39 PM
Often also used for rear window demisting so it's only on when the engine is running and battery is not low.
1998 300Tdi Auto Disco
#3 western
western
    Recovery Man
  • Moderators
  • 31,137 posts
Posted 21 October 2013 - 04:47 PM
as above it's to stop the rear screen heater being switched on & draining the battery when engine is of & alternator is not charging, if you look in the right corner there should be a metal tab for the VSS to fit on to, it's sits next to the rear screen heater relay.
Ralph, M3WRM, MSA Recovery Operator -- Western Recovery [Motorsport] http://www.amro.org.uk/
Defender Forum Moderator
Keep LR4x4.com Independent -- you can help by Clicking Here
#4 Tanuki
Tanuki
    Old Hand
  • Settled In
  • PipPipPip
  • 1,310 posts
Posted 21 October 2013 - 05:05 PM
Sometimes also used (as an alternative to a timer on the principle that "I've got this so I don't need to buy a timer") when retro-fitting a heated windscreen and/or heated mirrors.
#5 western
western
    Recovery Man
  • Moderators
  • 31,137 posts
Posted 21 October 2013 - 06:12 PM
& it's also used on some models with lights above the screen as a can't be switched on if engine is not running. to protect the battery from being flattened
#6 Maverik
Maverik
  • Supporters
  • 4,079 posts
Posted 22 October 2013 - 07:45 AM
Thanks guys, I think this might have solved the mystery of some empty relay holders on the 110 too...
