trickydicky Posted January 15, 2014 Share Posted January 15, 2014 hi all iv just brought a 200tdi and the glow plug relay was unplugged so I pluged it in and then it seemed to be stoping on and I was getting white smoke so I brought a new relay and that's the same . while digging around in the battery box I noticed the thick brown wire was connected to the negative can anybody tell me if this is correct ? I was under the impression brown was an unfused feed so I thought it would be possative not negative. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 15, 2014 Share Posted January 15, 2014 It should be connected to positive. That is the power supply for the plugs. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted January 15, 2014 Author Share Posted January 15, 2014 that's what I thought . now im wondering if the rest of it is correct has anybody got a diagram or something ? Quote Link to comment Share on other sites More sharing options...
Briarston Posted January 15, 2014 Share Posted January 15, 2014 Hi May be able to help with the connections. I should have a drawing ( it's at work) so will try and dig it out tomorrow, and get back to you if no one else beats me to it. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted January 15, 2014 Author Share Posted January 15, 2014 that's great if you could . I don't want to burn anything out so id rather check before I start moving wire around . Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 15, 2014 Share Posted January 15, 2014 http://forums.lr4x4.com/index.php?showtopic=85071 Quote Link to comment Share on other sites More sharing options...
western Posted January 15, 2014 Share Posted January 15, 2014 this should help as well as the link above. Quote Link to comment Share on other sites More sharing options...
