neonovice Posted April 14, 2014 Share Posted April 14, 2014 Hello, I have a problem with a 2003 TD5 110. It conked out on Saturday and now wont start. It turns over OK but wont fire. Having plugged it into a hawkeye I got back a fault at the crank sensor. I replaced it but it still won't start. The pump seems to be working OK (it was replaced about a month ago), I can hear it buzzing and there is fuel coming out the pipes. The ECU looks clean (no oil), and the immobiliser is switched off. Any ideas? Thanks. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted April 14, 2014 Share Posted April 14, 2014 Have you tested the crank sensor with a meter whilst spinning the engine? Was old sensor damaged at all? Did it have a spacer? Have you checked the wires to it? Andy Quote Link to comment Share on other sites More sharing options...
neonovice Posted April 15, 2014 Author Share Posted April 15, 2014 I tested idle speed (which measured a negative figure) it did effect the reading when I cranked it, is that the right test? The old sensor looked fine, there was no spacer and the wires to it are intact. Quote Link to comment Share on other sites More sharing options...
neonovice Posted April 16, 2014 Author Share Posted April 16, 2014 Put it into a local LR specialist. New pump. Only fitted one 6 weeks ago. It was a cheap one - will go for genuine this time I think.... Quote Link to comment Share on other sites More sharing options...
neonovice Posted April 17, 2014 Author Share Posted April 17, 2014 Put a new pump in and fired up. Now it isn't running right. Sounds like not all cylinders are firing, no fault codes though.... Quote Link to comment Share on other sites More sharing options...
neonovice Posted April 17, 2014 Author Share Posted April 17, 2014 Ordered a new DMF. Hopefully this will cure it. Quote Link to comment Share on other sites More sharing options...
Wildcat Posted April 21, 2014 Share Posted April 21, 2014 Try the injector seals, I had a similar problem changed mine and now o.k. Quote Link to comment Share on other sites More sharing options...
neonovice Posted April 21, 2014 Author Share Posted April 21, 2014 Gearbox is out. Just waiting on a dmf. If it doesn't sort it injector seals it is. Quote Link to comment Share on other sites More sharing options...
neonovice Posted April 28, 2014 Author Share Posted April 28, 2014 It was the injector seals!! Quote Link to comment Share on other sites More sharing options...
