gazelle Posted April 14, 2014 Share Posted April 14, 2014 Several years ago I fitted simonb's intermittent rear wiper modification, which is fantastic and works a treat. I have left it until now to start to implement the optional wipe while washing function, This involves running a wire from the remaining connector on the new relay and attaching the other end of the wire to the back of the washer switch. Some research tells me it is the black/green cable I need to connect to, but how should I do this? (2002 model TD5 90) The wire has been run to the back of the switch but there is no obvious way of making the connection without cutting into the wiring. What are my options? Martin Quote Link to comment Share on other sites More sharing options...
gazelle Posted April 15, 2014 Author Share Posted April 15, 2014 The questions really are: Can it be done without cutting the original wiring? To cut or not to cut? What connectors to use? What connectors not to use? Cheers Martin Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 15, 2014 Share Posted April 15, 2014 I'd just cut it and use an inline crimp. Quote Link to comment Share on other sites More sharing options...
gazelle Posted April 15, 2014 Author Share Posted April 15, 2014 Something like this? With two wires in one end and one in the other? Quote Link to comment Share on other sites More sharing options...
simonb Posted April 15, 2014 Share Posted April 15, 2014 Yes, that will work. Quote Link to comment Share on other sites More sharing options...
gazelle Posted April 15, 2014 Author Share Posted April 15, 2014 Cheers both. Now just need to find time to go and get them. Fantastic upgrade Simon, I now sometimes forget to turn it off. Martin Quote Link to comment Share on other sites More sharing options...
gazelle Posted April 15, 2014 Author Share Posted April 15, 2014 Just fitted the VW99 relay to the front, and it really is a 5 min job - getting the original relay out of its holder was by far the most difficult part of the job. Quote Link to comment Share on other sites More sharing options...
