fireblade7 Posted April 16, 2014 Share Posted April 16, 2014 got the chace maybe getting a couple off defenders 130 s td5 and a 300 tdi am i right in assumming they are the same chassis as the 110 ?? Quote Link to comment Share on other sites More sharing options...
Maverik Posted April 16, 2014 Share Posted April 16, 2014 No they are longer... 127" to be precise... the early "130"'s where just 110 chassis that had been lengthened, but later on they produced them as a proper 130" chassis. Other than them being longer in the mid section they are in effect the same as a 110... Quote Link to comment Share on other sites More sharing options...
western Posted April 16, 2014 Share Posted April 16, 2014 as above, these should be one piece [no extension visible] chassis, the VIN will tell you if it was a 110 prior to being converted to a 127/130 as these remain on a 110 VIN number. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 16, 2014 Share Posted April 16, 2014 The clue is in the name ... Mo Quote Link to comment Share on other sites More sharing options...
jacksta Posted April 18, 2014 Share Posted April 18, 2014 My 127/130 from 1988 is still showing as a 110 on the v5. A friend bought a much later 130 and was surprised when we measured both vehicles and found them both to be 127". I find its a great vehicle, just not as practical as a 110, not much space inside etc. Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2014 Share Posted April 18, 2014 My 127/130 from 1988 is still showing as a 110 on the v5. A friend bought a much later 130 and was surprised when we measured both vehicles and found them both to be 127". I find its a great vehicle, just not as practical as a 110, not much space inside etc. correct on the 110 V5 info as it would have been a factory conversion & wheelbase is 127 inches, 130 was just the model titles, so you had 90/110/130 = 20 inch difference between the models. Quote Link to comment Share on other sites More sharing options...
fireblade7 Posted April 27, 2014 Author Share Posted April 27, 2014 well now got 2 130s they show the middle extended on both 1s a td5 the other 300 tdi w reg and r reg both show the extension Quote Link to comment Share on other sites More sharing options...
western Posted April 27, 2014 Share Posted April 27, 2014 IIRC the 130 chassis was built as a full chassis after 300tdi came out, maybe both have extra strengthen plates welded on to make it stronger in the long part of the main rails. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 27, 2014 Share Posted April 27, 2014 If as Ralph suggests the plates are for strength. What is the GVW on the plate ? Quote Link to comment Share on other sites More sharing options...
fireblade7 Posted April 27, 2014 Author Share Posted April 27, 2014 If as Ralph suggests the plates are for strength. What is the GVW on the plate ? will check that i did see a plate on the inside of the ifor williams back both were x networkrail Quote Link to comment Share on other sites More sharing options...
fireblade7 Posted April 27, 2014 Author Share Posted April 27, 2014 would the gearboxes or axels ?be different from normal 110s ect?? i did notice that both 130s have a set of springs on the inside of the normal springs ?? thanks in advance mike Quote Link to comment Share on other sites More sharing options...
western Posted April 27, 2014 Share Posted April 27, 2014 Only difference is the internal small helper springs, everything else is the same. Quote Link to comment Share on other sites More sharing options...
western Posted April 27, 2014 Share Posted April 27, 2014 threads merged to keep the 130 info in one place Quote Link to comment Share on other sites More sharing options...
fireblade7 Posted April 28, 2014 Author Share Posted April 28, 2014 If as Ralph suggests the plates are for strength. What is the GVW on the plate ? maximim autherised mass3500kg Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 29, 2014 Share Posted April 29, 2014 maximim autherised mass3500kg That GVW means a heavy duty chassis. Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 1, 2014 Share Posted May 1, 2014 PICTURES :i-m_so_happy: :i-m_so_happy: :i-m_so_happy: Quote Link to comment Share on other sites More sharing options...
