Sinclair Posted April 16, 2014 Share Posted April 16, 2014 Newbie prob. Reversing light only comes on when sides and mains are off. Any ideas? Any help much appreciated. Quote Link to comment Share on other sites More sharing options...
AndrewHorsfield Posted April 17, 2014 Share Posted April 17, 2014 I am assuming you mean that it only comes on when reversing and the other lights are off. In which case it is probably a bad earth behind the lights. If it comes on when not reversing, then it is probably plugged into the wrong socket on the loom, again behind the lights. Just inside the rear door on both sides there is a cover. Behind these are the connections for the lights. Quote Link to comment Share on other sites More sharing options...
Sinclair Posted April 17, 2014 Author Share Posted April 17, 2014 Thanks! Quote Link to comment Share on other sites More sharing options...
Sinclair Posted April 21, 2014 Author Share Posted April 21, 2014 Its not a bad earth as far as i can see. There are two wires to the reversing light - its not earthed to the body at the light itself. With no lights on it gets 8.3 volts and with lights on its getinng 0.3 volts. Anyone got any ideas? Quote Link to comment Share on other sites More sharing options...
western Posted April 21, 2014 Share Posted April 21, 2014 grren/brown is from the reverse light switch = 12v feed & the plain black earth should be attached to body inside in the rear corner behind the rear light cover. if those are OK, try another switch on gearbox. Quote Link to comment Share on other sites More sharing options...
Sinclair Posted April 22, 2014 Author Share Posted April 22, 2014 Thanks. The prob is not just getting it to work. The green/brown voltage drops to almost zero when the sides or mains are on. When they are off it is all ok - voltage not really 12 its just over 8v but still lights the bulb ok. Si it all works as it should when lights are off but gree/brown drops to 0.3 when sides or mains are on. Quote Link to comment Share on other sites More sharing options...
western Posted April 22, 2014 Share Posted April 22, 2014 the green/brown should be connected to any other lights, sounds like a previous owner has bodged the wiring. Quote Link to comment Share on other sites More sharing options...
Sinclair Posted April 23, 2014 Author Share Posted April 23, 2014 You're right. Strange wiring. Someone had conected the earth to a spare loom connection that went to 12 when lights on. Strange because the bullet on the rev light earth wire looked original. Anyway I earthed it at the light like you said and it works like it should now. Thanks. Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2014 Share Posted April 23, 2014 your welcome, glad to read it was a fairly easy & not expensive fix. Quote Link to comment Share on other sites More sharing options...
