Phil Posted April 22, 2014 Share Posted April 22, 2014 I've just got an '08 DCPU and noticed that the rain gutter is almost filled with mastic. This looks to be how the vehicle came out of the factory; are they all like that? If they are, has anyone fitted a roofrack? If so, how did you get on? Strikes me there'll be mastic everywhere trying to get a firm footing for the mounts. Phil. Quote Link to comment Share on other sites More sharing options...
bpman Posted April 27, 2014 Share Posted April 27, 2014 I have come across this on a previous puma, the gutter was almost full but there was a gutter, maybe 3-4mm .. are you saying the gutter is full ? if so, when it's a warm day it goes soft, remove some for the rack feet or rack foot rail. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted April 27, 2014 Share Posted April 27, 2014 Tricky one because there is a seam at the bottom between the roof sheet and the frame. The gutter is part of the frame so the danger is that if you remove too much, water will get under the sheet, into the inside channel - then it's a lottery whether you or the passenger get soaked.. Quote Link to comment Share on other sites More sharing options...
Phil Posted April 28, 2014 Author Share Posted April 28, 2014 The gutter is full to within 1mm-2mm all round. I'm concerned that digging it out is likely to crack the paint, and I risk of exposing whatever seams lie beneath. It doesn't leak at the moment and I'm enjoying staying dry! Perhaps best forget the roofrack. Thanks, Phil. Quote Link to comment Share on other sites More sharing options...
