islandbluenose Posted July 19, 2014 Share Posted July 19, 2014 Hi. I hope someone can help- ive got a 200tdi 90. It goes great apart from when I put the headlights on. When the headlights are on the temp. Gauge goes up ro red. When the lights are put off the gauge goes back to normal. (Straight up) ive also noticed when the headlights are on the wipers slow right down.any help would be apreciated. Cheers. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 20, 2014 Share Posted July 20, 2014 You'll find that this type of problem is usually down to poor earthing. Locate and clean up your earthing points and I suspect you will find all is well. HTH Mo Quote Link to comment Share on other sites More sharing options...
islandbluenose Posted July 20, 2014 Author Share Posted July 20, 2014 Ok. I'll try that. Thanks. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted July 21, 2014 Share Posted July 21, 2014 I agree with Mo, it's most likely an earthing issue. Pay particular attention to the instrument earthing wires - they're often secured to the instrument clamp bracket, which in my experience can come loose over time. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 22, 2014 Share Posted July 22, 2014 Any success ? Quote Link to comment Share on other sites More sharing options...
islandbluenose Posted July 24, 2014 Author Share Posted July 24, 2014 Yes- cleaned the main earth points and now everything is working perfect. Thanks everyone for the tip. Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2014 Share Posted July 24, 2014 there's a bunch of black earth wires near the brake servo, bolted to bulkhead, clean those up too, if you haven't done so already. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 24, 2014 Share Posted July 24, 2014 I bought a 110 once and driving it home I was concerned that the temperature gauge was reading a bit high, even pulled over a few times to let it "cool down" to no avail. Then sitting at a junction indicating I realised that the gauge was bouncing in time with the indicators! I could alter the temperature by adding or removing various electrical loads - lights, heater etc. I looked underneath when I got home and there was a small-ish lead from the battery negative hanging down near the sump with a ring terminal on it, and one of the sump bolts had a witness mark around it so I put it on there and from then on no problems. Never seen such a lead on any other Land Rover but it did the job here, I can only presume that there had been a problem with the main earth strap at some point and a previous owner had put this earth lead on as a fix, and then forgotten to re-attach it after having the sump off for some reason. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 27, 2014 Share Posted July 27, 2014 Glad to see you've sorted it. Mo Quote Link to comment Share on other sites More sharing options...
Prith Posted July 28, 2014 Share Posted July 28, 2014 Am having the same problem. Where are all the earthing points on a 110 Quote Link to comment Share on other sites More sharing options...
Jode Posted August 5, 2014 Share Posted August 5, 2014 The battery earth points are at the transfer box IIRC; the lights earth "locally"; the instruments behind the binnacle I think. They're all over the place.... Quote Link to comment Share on other sites More sharing options...
western Posted August 5, 2014 Share Posted August 5, 2014 Earth from battery to main gearbox to transfer box joint & a thick earth lead from chassis part of left engine mount to the alternator & power steering pump bracket on engine block for 200tdi engines Quote Link to comment Share on other sites More sharing options...
