gazelle Posted August 24, 2014 Share Posted August 24, 2014 Not up to the usual level of this forum, but I am struggling with this one, How are the rear bumpstops held onto the chassis? One of mine was recently notices by the MOT chap to be missing. I have located two nuts but one just rotates without loosening and the other is currently a bit to stiff to undo - more plusgas. Any hints as to what needs to be done to get the pesky thing off would be gratefully received. Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted August 24, 2014 Share Posted August 24, 2014 The rubber bumpstop is bonded to a steel plate which is held to the chassis with two bolts. There is one bolt each end which I guess are the ones you can see. They are not captive. If they are rusted up you're probably better off cutting them off. HTH. Quote Link to comment Share on other sites More sharing options...
gazelle Posted August 24, 2014 Author Share Posted August 24, 2014 Ok, so the bolt head must be encased in mud which will need to be removed before I can get a spanner to it! That is the bit that I was missing. I will continue with the plusgas for the time being, and think about cutting them away when I get bored. Cheers Paul. Quote Link to comment Share on other sites More sharing options...
western Posted August 24, 2014 Share Posted August 24, 2014 picture here item 10 is the bumpstop http://lrcat.com/#31/4/52630 plate on chassis has a slot each end, so just cut the nuts off & then lever the old bumpstop off. Quote Link to comment Share on other sites More sharing options...
gazelle Posted September 2, 2014 Author Share Posted September 2, 2014 It has now. Had to use the grinder in the end to cut it off. But job done and new one fitted. Thanks chaps. Quote Link to comment Share on other sites More sharing options...
