sighnbox Posted August 26, 2014 Share Posted August 26, 2014 Hi guys simple one for you who done it...I had to remove my snorkel today to fit a pipe up inside for the wading kit and now need to re seal it unfortunately the garage who re sprayed her used some black rubber **** what was like a rubbery supper glue I nearly ripped me panel off trying to get it off and it pulled the paint off (so first job re paint where the snorkel fits....and had to cut carefully he rubber what was left as no way it was coming off.......right mess it made as you can see from the pic..... ...any way whats best to use to re seal it ??? ...I have a tube of black RTV silicone sealant that I used when re fitting the sun roof surround and sealing it shut It says on the tube waterproof ADHESIVE sealant....I don't want it stuck on like before where I cant even get the thing off and not to sure how adhesive this RTV stuff is .... Quote Link to comment Share on other sites More sharing options...
heath robinson Posted August 26, 2014 Share Posted August 26, 2014 I use Tigerseal for pretty much everything I want to stay. Sticks like carp to a blanket, polyurethane adhesive/sealant about £6 off ebay. It's what they hold windscreens in with in the modern world! We use it to hold solar panels onto van roofs, a blob on a mount on each corner will hold one of them on at 80mph, so that'll explain why it's made a mess of yer paint. I think that "Sticks like carp" stuff, or any other flexible building adhesive would do you really. Quote Link to comment Share on other sites More sharing options...
heath robinson Posted August 26, 2014 Share Posted August 26, 2014 Bloody swear filter, the stuff is actually called "Sticks like Sh*t". Not a PU sealant. Quote Link to comment Share on other sites More sharing options...
sighnbox Posted August 27, 2014 Author Share Posted August 27, 2014 The one positive thing is its all behind the snorkel so once Ive touched the bare metal up and replaced the snorkel none of it will be seen Quote Link to comment Share on other sites More sharing options...
studmuffin Posted August 27, 2014 Share Posted August 27, 2014 Think Sikaflex EBT is similar stuff they use on boats and caravans and comes in black. Cheers Barry Quote Link to comment Share on other sites More sharing options...
Boydie Posted August 28, 2014 Share Posted August 28, 2014 Agreed, use Sikaflex panel sealer, it's expensive but well worth it if you want a long lasting - as in years - water-proof and weather resistant seal. Quote Link to comment Share on other sites More sharing options...
ajh Posted August 31, 2014 Share Posted August 31, 2014 If you're not trying to glue it in place and don't want this to happen again, plumbers putty or glazing strip will work fine. Quote Link to comment Share on other sites More sharing options...
