Tanuki Posted August 28, 2014 Share Posted August 28, 2014 On my 90TD5 I've noticed an odd wear-pattern on the front tyres. It's running 750/16 General SAGs. On the tread on the inner faces of both front wheels, the tread-blocks are developing a curious stepped pattern. Alternate tread-blocks seem to be wearing down more rapidly than their neighbours. It's the same on both front tyres. The difference is something like 4mm between blocks - enough to create a noticeable rapid 'wubwubwub' sound audible when you have the windows down. Tracking and 4-wheel-alignment has been checked by a friend who has access to the laser-gear used to set up rally-cars and is spot-on. Brakes are fine - I can do a pedal-to-the-metal lock-all-4-wheels stop from 50MPH and it pulls up dead straight without needing to hold the steering. Any ideas about what to check next? Quote Link to comment Share on other sites More sharing options...
steve b Posted August 28, 2014 Share Posted August 28, 2014 what is the tracking set at ? I run mine at 0 degrees Kingpins all good? and bushes on the hockey sticks ? and what tyre pressures ? cheers Steveb Quote Link to comment Share on other sites More sharing options...
Tanuki Posted August 28, 2014 Author Share Posted August 28, 2014 what is the tracking set at ? I run mine at 0 degrees Kingpins all good? and bushes on the hockey sticks ? and what tyre pressures ? cheers Steveb All the geometry's good as are the bushes track-rod-ends and kingpins. Tracking is 0 degrees. No signs of "death-wobble" or other dynamic issues. No lift or uprated springs or anything. Only change from standard is Bilstein yellow gas shock-absorbers all round. Use is almost entirely on-road, including some trailer-towing. Tyre pressures 32 front 36 rear. Looking at the wear-rate these front tyres are only going to manage 20,000 miles before the inside edges are nuked beyond legality. Quote Link to comment Share on other sites More sharing options...
steve b Posted August 28, 2014 Share Posted August 28, 2014 maybe slightly higher tyre pressures would help? 40psi front 45psi back? the SAG is a blocky tread so maybe stiffer tyre walls will help? cheers Steveb Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted August 28, 2014 Share Posted August 28, 2014 sounds like the tires are sawtoothing or cupping. dunno the exact cause. something to do with excess axle oscillation. (aka Donald ducked shocks) Quote Link to comment Share on other sites More sharing options...
