ajh Posted August 30, 2014 Share Posted August 30, 2014 Is there any reason not to swap late-model axles to an older (200TDI) 110? Any reasonable sources? Shipping will of course be expensive either way. Quote Link to comment Share on other sites More sharing options...
muddy Posted August 31, 2014 Share Posted August 31, 2014 Don't forget you'll require a longer propshaft. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 31, 2014 Share Posted August 31, 2014 Aren't the Puma rear axles weaker? More specifically the diffs, I'm sure I read somewhere about a number failing. What's your motivation for the swap? Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted August 31, 2014 Share Posted August 31, 2014 Puma front diffs were all two pin up to around 2011 after which four pins are fitted. You'll want to source parts from a reputable source, far too many Defenders go missing or have bits pinched from them by the light fingered brigade. Quote Link to comment Share on other sites More sharing options...
muddy Posted August 31, 2014 Share Posted August 31, 2014 Are you saying all post 2011 pumas have a long nose 4pin up front? Will Quote Link to comment Share on other sites More sharing options...
ajh Posted August 31, 2014 Author Share Posted August 31, 2014 I'm a long way from being able to even see one up close. Basically I was after the internals, swivels etc. If someone was willing to pull just the parts I need that would be good. Any chance they have the steering arm on both swivel housings as the D2s etc do? I'm still on the bushing style of swivel and I think the swivels I got were poorly made. I get a lot of unexplained movement that can't be attributed to bearing preload etc so was just figuring that if I was going to update things it might be easier to just get complete units and ship those. Quote Link to comment Share on other sites More sharing options...
