diggervan Posted September 13, 2014 Share Posted September 13, 2014 Hi does anyone know if I fit rear led's will the trailer light and busser in dash still work or will I have to Get a relay box like you do on trailers if you swap to led's Thanks bob Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 14, 2014 Share Posted September 14, 2014 The bolton bits set of lights and relay works fine with a trailer though you do need to adjust the relay after first fitting and when you first connect a trailer. After that no problems till it shows all your bad earths up (ours doesn't have a buzzer but the dash light works fine.) Mike Quote Link to comment Share on other sites More sharing options...
AndrewHorsfield Posted September 14, 2014 Share Posted September 14, 2014 I think you can buy a flasher relay for LED lights? I think Paddocks had them when I investigated it before. This might mean switching all indicators to LED. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 14, 2014 Share Posted September 14, 2014 This might mean switching all indicators to LED.I'm fairly sure the bolton bits relay is adjustable to allow for some lights led and some not. My side repeaters are still bulbs.Mike Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted September 14, 2014 Share Posted September 14, 2014 I have recently transferred the RDX LED indicator, side and stop lamps from my 2010 Puma to my new one, the side repeaters remain as per standard. The adjustment on the LED flasher from Bolton Bits is to set the correct level so that the trailer tell tale lamp in the vehicle fitted with LED indicators flashes when a trailer is connected and not flash when there is no trailer present - just as the tell tale would if you had a standard flasher and bulbs. Quote Link to comment Share on other sites More sharing options...
AndrewHorsfield Posted September 14, 2014 Share Posted September 14, 2014 Thanks. Worth knowing as more LED bulbs are on the wish list Quote Link to comment Share on other sites More sharing options...
western Posted September 14, 2014 Share Posted September 14, 2014 Thanks. Worth knowing as more LED bulbs are on the wish list not strictly legal to fit led into lights made for normal bulbs, better to swap the complete unit for 'E' marked sealed led lights. Quote Link to comment Share on other sites More sharing options...
diggervan Posted September 14, 2014 Author Share Posted September 14, 2014 Ah no real probs then thank's for all the replys bob Quote Link to comment Share on other sites More sharing options...
supaimpy Posted September 16, 2014 Share Posted September 16, 2014 not strictly legal to fit led into lights made for normal bulbs, better to swap the complete unit for 'E' marked sealed led lights. why not? I know HID headlamp conversions arn't legal but never heard about LED bulbs Quote Link to comment Share on other sites More sharing options...
western Posted September 17, 2014 Share Posted September 17, 2014 because the lens is not designed to give the correct spread of light with led internals, but doubt ant MOT or Police would know. Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted September 17, 2014 Share Posted September 17, 2014 Sealed LED units are 100 times better than using LED bulbs in the standard lights anyway, changed mine from LED bulbs to the Bolt on Bits lamps after being advised that mine weren't strictly legal. Wish I had done it to start with as they are just so much better. Quote Link to comment Share on other sites More sharing options...
KKMobile Posted September 23, 2014 Share Posted September 23, 2014 ^^^^^^^^^ What he said ^^^^^^^^^ Quote Link to comment Share on other sites More sharing options...
