rallycinq Posted September 15, 2014 Share Posted September 15, 2014 Hi Guys, done a search, can't find anything relevant, although I expect a flaming from the 'viscous brigade'. I have obtained a new aluminium radiator with electric fan fitted. The fan is a two wire, the sender unit in the rad has three poles. The supplier has sent some instructions from a 'similar' sender and they involve a switch in the cab. I'd rather not have that, so I am thinking of handing back the three pole switch and fitting an adjustable controller to the rad so I can fit and forget. Is this sensible, oh wise ones? Cheers D ps 1991 110 200TDi CSW Quote Link to comment Share on other sites More sharing options...
Team Idris Posted September 15, 2014 Share Posted September 15, 2014 My Alisport three terminal is a two-in-one package. So if you had two fans one would cut in before the other. But.....I figure you can connect the lower temp side through a resister and the second connection direct (bypassing resistors effect). Then you get a two speed temperature controlled fan This is in my mind because I have the big 20 amp Kenlow running all the time with two speeds via a switch. Plus two pusher fans on the thermostat. If I could keep the Kenlow on Low speed until it is really needed I'd save battery a fair bit. I re-read that and need to point out that the Kenlow runs all the time the ignition is on and I select low speed for trialing and full 20amp for winch challenge. I'm immune from the viscous debate because the rad is in the back I re-re-read that and need to point out that my three terminal sender only has one side used, so there is no third wire on it right now. I think the switch on your diagram will be an over-ride function? If you went that way you could start cooling before the steep hill? But it could be a wading switch? Which sounds like a head-gasket on-off switch Quote Link to comment Share on other sites More sharing options...
rallycinq Posted September 15, 2014 Author Share Posted September 15, 2014 Thanks for that. I can't find out who the manufacturer is. I think its a two temperature switch, so I suppose I could just use one side of it (which side though) Cheers D Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 15, 2014 Share Posted September 15, 2014 Charge ! Mo Quote Link to comment Share on other sites More sharing options...
Team Idris Posted September 16, 2014 Share Posted September 16, 2014 Mine has two spade facing one way and one at a right angle, which is the battery feed (fused). Quote Link to comment Share on other sites More sharing options...
rallycinq Posted September 16, 2014 Author Share Posted September 16, 2014 Mine has two spade facing one way and one at a right angle, which is the battery feed (fused). mine has too, I just need to work out which of the two parallel ones is the high temperature one..pot of water on cooker and multimeter to the rescue Cheers D Quote Link to comment Share on other sites More sharing options...
