RGK Posted September 30, 2014 Share Posted September 30, 2014 Hi, Ive replaced both axles with 300tdi, to ensure the brake arent under servo'd ive replaced the existing servo and master cylinder with the from the 300tdi. It took a bit of effort to redrill the two mounting holes...then I thought last night 'could I have used the original 2.5na servo with the 300tdi master cylinder?' Any thoughts and advise greatly welcome Thanks Quote Link to comment Share on other sites More sharing options...
western Posted September 30, 2014 Share Posted September 30, 2014 nope, 300tdi master cylinder to servo has a different bolt pattern offset studs to your old master cylinder & servo inline studs. your old servo & master cyl would have worked fine with the 300tdi brakes. Quote Link to comment Share on other sites More sharing options...
robertspark Posted October 5, 2014 Share Posted October 5, 2014 If the original rear axle was drums, you probably want to think about the brake bias, which is controlled from the valve on the front chassis / bulkhead. discussion here: http://forums.lr4x4.com/index.php?showtopic=70785&hl=%2Bdisc+%2Bbrake+%2Bconversion#entry770624 Quote Link to comment Share on other sites More sharing options...
