How soon should I change these brake pads?
My front brake pads are getting a bit thin, I haven't touched the front brakes in the 5 years I have owned the landy (only do 4K miles a year) so I thought I would take the opportunity to give the them an overhaul. I've ordered a set of mintex discs, mintex pads, new OEM seals and bearmach stainless steel pistons. The thing is, I have an 800 mile round trip to Scotland next week with an RTV/Navigation style event when I'm there and I will be really pushed for time to do the work before then. The picture below shows the worst side and I'm after an opinion of how much pad material is an acceptable amount and whether it is appropriate to leave the work until I get back? The thinnest pad currently measures 3mm.
They recommend to change them at around 3mm.
But if you think about it, that one pad is about 2/3rds worn away, which lets say has done 20,000 miles (guessing). So realistically theres more than 800 miles left in the pad.
Ive ran them much lower than that in the past. And personally wouldnt be too worried about that, seen far worse. But thats just my opinion, the experts will help you out more than i can. Just my thoughts to try and help :)
In my opinion, they need servicing right now! They are in a right state, and five years of doing nothing, plus you obviously off road so get them full of grit, they are long over due.
That's my opinion.
Will they get you to Scotland and back safely? Yes I think they would. Is she still pulling up nice and straight, and responding well to the pedal? If so, then at least everything is still working as it should.
Can't see well from your picture but depending on the state of the pistons in the calipers, they may need looking at as well. Running the pads low leaves the piston exposed to the worst salt, dirt road muck. This will eat at them more than if you are running new pads which sit in the caliper.
Pete
Ah didn't see that past my sandwich. :blush: In that case if they are still doing the job, it's definitely a job for when it gets back, pushing the rusty pistons back in before an 800 mile trip could be asking for trouble.
Or if it isn't broke yet, don't tempt it with a small fix/repair which will turn it into a bigger job or break it sooner.
Pete
I actually thought it would be ok to leave until after my trip but just wanted a second opinion really, its good to know that others think the same. Yes it's still pulling up nice and straight so I haven't got any concerns there. I will get on the job as soon as I'm back, that way I can take my time and do the job properly. Thanks for all the input.
