tegwin Posted November 21, 2014 Share Posted November 21, 2014 Hi Guys, have a bit of an odd issue... Standard TD5 defender with remote central locking. Was working fine but recently it has started unlocking its self and sounding the alarm/horn. I can lock the truck with either the key or the remote and all seems fine. Then around 5-6 hours later it unlocks all the doors... (Not very safe!) I have tested the functionality of all the door switches and pulled the drivers master solenoid out of the door to make sure it is working without binding up. Cant find any fault anywhere... However, if I lock all the doors and unplug the drivers door solenoid wiring loom the truck stays locked... I suspect the issue is either with the alarm ecu or the door solenoid but no idea which or how to work it out... Weird that its just randomly started happening.. Any thoughts? I can't really live with a truck that unlocks its self!! Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 21, 2014 Share Posted November 21, 2014 Is it weather related? Quote Link to comment Share on other sites More sharing options...
davie Posted November 21, 2014 Share Posted November 21, 2014 mine was doing this, check all door pin switches and if any doubt change them. then check interior lights as that caused mine to act up second time. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted November 23, 2014 Share Posted November 23, 2014 My old truck used to do this, worse in the cold. Fitted new drivers door actuator, then solved. Andy Quote Link to comment Share on other sites More sharing options...
101sean Posted November 23, 2014 Share Posted November 23, 2014 Bro in laws 130 did the same, new drivers door actuator fixed it. Quote Link to comment Share on other sites More sharing options...
Escape Posted November 24, 2014 Share Posted November 24, 2014 My 2005 sometimes did the same, I think it started after I removed the interior lights and part of the wiring loom when putting in the roll cage. I always suspected the drivers door switch, but never fully investigated. Quote Link to comment Share on other sites More sharing options...
