oneandtwo Posted February 26, 2015 Share Posted February 26, 2015 Is their a guide or manual for the 4 bolt steering box rebuild? I have an almost new genuine landrover box that someone drove for a couple of thousand miles with a loose drop arm and ruined the splines on the sector shaft; there were no fluid leaks or damage/play to the box, I've stripped it down and it's all good inside. I have an identical box with a leaking input shaft I was going to swap the sector shaft out of but wanted to know the correct procedure for aligning the sector shaft teeth with the teeth on the piston ram. Thanks. Quote Link to comment Share on other sites More sharing options...
ballcock Posted February 26, 2015 Share Posted February 26, 2015 Down load a copy of the rave manual. I think there is a overhaul procedure in there. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted February 26, 2015 Author Share Posted February 26, 2015 Just found it on my rave manual, I didn't think it covered power steering box overhaul but I was mistaken.. Thanks Quote Link to comment Share on other sites More sharing options...
