o_teunico Posted March 13, 2015 Share Posted March 13, 2015 Hi all, I have ignored one of the Land Rover owner´s rule "If your Landy stops leaking, you should check the oil level". As a result, one of the front UJ is seized. I would like to ift AEU2522 CVs instead of the the UJs, but for that I need some 10/23 halfshafts, as used in the Stage One V8. Is out there somewhere to buy cheapo replacements? I have been able to locate some NOS, but priced as gold! Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 13, 2015 Share Posted March 13, 2015 not really sadly, HeyStee in Netherlands makes some, but these are not cheap either. By far the cheapest and easiest solution is to keep running u-joints Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 13, 2015 Share Posted March 13, 2015 There was a motorsport engineering works that would make them up for not mad money discussed a while back - I did bookmark it, but the link is gone. I'll do some digging. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 13, 2015 Share Posted March 13, 2015 Here it is: http://berrisford.co.uk http://berrisford.co.uk and here's the thread: http://forums.lr4x4.com/index.php?showtopic=84930&page=3 Quote Link to comment Share on other sites More sharing options...
missingsid Posted March 13, 2015 Share Posted March 13, 2015 KAM made a set of RRC shafts that they will cut down to Stage 1 size for you. Problem is that you cannot order them through the supplier you need to get the mobile number from the old website. I have a set in my hybrid Series/RRC axles. Marc Quote Link to comment Share on other sites More sharing options...
o_teunico Posted March 14, 2015 Author Share Posted March 14, 2015 Thanks for the info. Today I have taken out both front halfshafts. If I keep UJs I will need to change the left shaft, not just the UJ Quote Link to comment Share on other sites More sharing options...
o_teunico Posted March 14, 2015 Author Share Posted March 14, 2015 Here a crazy idea...what if a standard coiler shaft is shortned and resplined to suit the 10 spline series diff? Is heat treatment really a must? Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted March 14, 2015 Share Posted March 14, 2015 that could be done, factory LR shafts are not heat treated, only the pattern crappy ones. There is quite a bit of involved though, as you'll have to make race for the bearing in axle housing that fits over the rrc shaft, and clearance for the CV in swivel, etc etc Quote Link to comment Share on other sites More sharing options...
o_teunico Posted March 14, 2015 Author Share Posted March 14, 2015 I will talk to local machining shop to see how much they want for making the job. Quote Link to comment Share on other sites More sharing options...
Meph373 Posted April 13, 2015 Share Posted April 13, 2015 I have a set of CV Shafts. They're brand new. I'll certainly sell them for less than the 280 Pounds that that Rovers North sells them for. Quote Link to comment Share on other sites More sharing options...
firemanshort Posted April 17, 2015 Share Posted April 17, 2015 Do you have Stage One axles / CVs? Where are you located? I could be interested. Quote Link to comment Share on other sites More sharing options...
