golfball4157 Posted March 23, 2015 Share Posted March 23, 2015 Hi not sure if I'm in the correct section but here goes... Just wondering if the defender r380 transfer box selector unit with stick is the same as the 300tdi disco one...and also can you just take the stick out on its own? Thanks a lot people Alex Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2015 Share Posted March 24, 2015 no they are not the same, defender one sits behind main gearlever whereas Discovery sits in front of main gearlever. Quote Link to comment Share on other sites More sharing options...
golfball4157 Posted March 24, 2015 Author Share Posted March 24, 2015 would i be able to strip both selectors down and use a disco stick in defender selector? what the problem is is that the low range gear stick got bent while the gbox was out and now cant get one was guna try a disco stick in defender housing cheers alex Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2015 Share Posted March 24, 2015 both hi/low levers have different part numbers for each model range, I'm not sure if the physical part is the same. Quote Link to comment Share on other sites More sharing options...
