daveturnbull Posted March 30, 2015 Share Posted March 30, 2015 Righty then. I've got a set of the wipac headlights with provision built in for sidelights. Never made use of them before, but I've come up with a cunning plan for some stealth strobes to be used strictly off road when attending various marshaling 'incidents' at comp safaris. So I found out what flavour of LED bulbs I needed, and bought a pair off eBay. They turned up today so I thought I'd grab 5 minutes after little 'un's bath / bottle / bed routine to fit them in the headlights. Anyone else managed to get bulbs in there? Just about the most inaccessible stupidly fiddly impossible little space ever. After about 15 minutes of hooked finger, knuckle skin removing swearing I gave up and used a little pry bar to lever the whole bulb holder out of it's hole in the lense. This promptly broke the lip off the holder. Grrrrrrr. So bulb is now in, much superglue has been applied, and it's drying in the vice. Any tips before I make a complete ar$e of the other one? Quote Link to comment Share on other sites More sharing options...
western Posted March 30, 2015 Share Posted March 30, 2015 My headlights have 'pilot' lights, they are meant to be fitted with headlight unit off the vehicle or at the very least out of the headlight supporting bowl, can all be done from the front of the vehicle without getting injured. Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted March 30, 2015 Share Posted March 30, 2015 I wouldn't use superglue as the reflective surface of the lamp will go dull / frosted. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted March 31, 2015 Author Share Posted March 31, 2015 Headlights are off the car, so that's not the issue. I might just have to pry out / glue back in the 2nd one aswell. Superglue is only on the back, not the reflective surface. It's quite old and gloopy so little chance of it seeping through too. Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted March 31, 2015 Share Posted March 31, 2015 its the vapour from the superglue that causes the problem, hope it works out. Quote Link to comment Share on other sites More sharing options...
