200tdi fuel tank change help
hi all iv got a 200tdi defender 90 with the tank on the drivers side . can anybody tell me the easiest way to change the tank? is it from the top or the bottom ? what do I need to remove to make things easier as I need room to replace the tank outrigger
Its a nut and bolt job, as said, from the bottom, however the last one I did, I had a hell of a job getting the old tank out, perseverence got the job done, it's a fiddle getting the new tank in as well, at the factory I bet the tank is fitted to a bodyless chassis....the fuel filler pipe is an absolute joy, rusted jubilee clips and not much room....
Good Luck!
Paul
