trickydicky Posted July 26, 2015 Share Posted July 26, 2015 hi all I have a 1990 200tdi defender that leakes from the bell housing . I did the tappets yesterday and while giving it a real good run the clutch started to slip in 4th and 5th when pulling hard . I had a new clutch and recon box fitted 1000 miles or so ago so im assuming its oil on the clutch . if it is my rear main what are my options for changing it I dont have a drive or garage or the money to pay somebody to change it . am I better of droping the gearbox or removing the engine ? has anybody got any pics of themselves doing this job so I can get a better idea ? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted July 26, 2015 Share Posted July 26, 2015 Check your clutch pedal is adjusted correctly and the slave is returning properly. A collapsed hose or knackered seals can lead to a slow return thus a slipping clutch. But as you say you have a leak your probably right personally I would either slide the gearbox back enough to get in there if you can or drop it completely. Just remember you'll need as new friction plate if it's contaminated. Mike Quote Link to comment Share on other sites More sharing options...
Lewis Posted July 26, 2015 Share Posted July 26, 2015 If you intend to do it as the workshop manual recommends by removing the flywheel housing from the block then taking the engine out is really the only way to go You can change the rear crank seal without stripping the flywheel housing but I've had more success doing it as the manual says Either way make sure you use a genuine crank seal or you'll be doing it again in a month or so Quote Link to comment Share on other sites More sharing options...
trickydicky Posted July 26, 2015 Author Share Posted July 26, 2015 im going round the engine sorting all the usual leaks all the front end is done is it worth removing the back plate wile the box is out and is it just gaskets like the front ? if I remove the gearsticks will it go back or do I need to remove the seat box ? Quote Link to comment Share on other sites More sharing options...
ejparrott Posted July 26, 2015 Share Posted July 26, 2015 If you don't keep the wading plug in then the oil should just drop out of the bottom. My gearbox is leaking, and I've had a leaky rear main, but neither have contaminated the clutch. Are you sure it's not just adjustment? Quote Link to comment Share on other sites More sharing options...
trickydicky Posted July 26, 2015 Author Share Posted July 26, 2015 I need to investigate a bit more Quote Link to comment Share on other sites More sharing options...
western Posted July 26, 2015 Share Posted July 26, 2015 could be the gearbox front seal leaking too. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted July 26, 2015 Share Posted July 26, 2015 If you search in the technical archive section there's a post in there by white90 gearbox-clutch-rear crank seal on a defender, this might help you its got pictures and a guide Quote Link to comment Share on other sites More sharing options...
discomikey Posted July 26, 2015 Share Posted July 26, 2015 I managed to pull my flywheel housing off whilst the engine was in the vehicle, although mine is a conversion. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted July 26, 2015 Author Share Posted July 26, 2015 ok iv brought thread lock bearmach rear main seal gearbox seals and gasket set transferbox seal and gasket set and a clutch kit .I just need to get biscuits teabags and milk . can you think of anything else I might need ? Quote Link to comment Share on other sites More sharing options...
steve b Posted July 26, 2015 Share Posted July 26, 2015 The gasket behind the flywheel housing ? they do fail and it's much easier to fit the seal off the engine then pull it over the sleeve with the bolts .... cheers Steveb Quote Link to comment Share on other sites More sharing options...
discomikey Posted July 27, 2015 Share Posted July 27, 2015 good shout steve, when i changed my rear crank seal i realised it was the gasket that had failed and not the seal!!! Quote Link to comment Share on other sites More sharing options...
trickydicky Posted July 27, 2015 Author Share Posted July 27, 2015 ye iv got one of them in the gasket set I brought for the front of the engine Quote Link to comment Share on other sites More sharing options...
