Which bolts for mounting transfer box
ok so last week I swapped my 1.2 lt230 for a 1.6 lt230 and went to refit the 1.6 today. Problem is the upper bolt near the diff lever and the very top bolt at the rear of the box no longer tighten. Anyone any idea what bolts I require? Cheers
Also be careful as the 2 bolts that thread into the transfer box from the gearbox side need to be shorter than the rest, otherwise they will do up fine but will be touching gears inside and create swarfy mess
