cold_n_wet Posted July 26, 2015 Share Posted July 26, 2015 Im in the process of getting the V8 rebuilt to go in the 85 - ninety The engine on the bench has had the rings and big end bearings, done and my mechie is wondering how to change the camshaft bearing, one is difficult to get to and change apparently, im not to familiar with this engine, hence why ive let my mechie mate do the spannering on this one. Any information or help is appreciated. Cheers Glen Quote Link to comment Share on other sites More sharing options...
Team Idris Posted July 27, 2015 Share Posted July 27, 2015 I think the last one is in a blind hole. You would need a special puller thing I think? Some talk of having to line bore or ream them after, but that seems unlikely. They are just weird because they are all different sizes? I didn't bother doing them on mine because I do so little mileage, but it has to be worth doing to have a nice engine. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted July 27, 2015 Share Posted July 27, 2015 Done properly all bearings are removed reached then line bored to ensure each lines with the next etc. You can get bearings which are sold as not needing lin boring ....That's cos the tolerances are larger. .. Either works but qst route is way better Quote Link to comment Share on other sites More sharing options...
mickeyw Posted July 27, 2015 Share Posted July 27, 2015 Is there not a core plug behind the last bearing? When I had cam bearings replaced some years ago, they were line honed after being pressed in. This work wad done by Turners. I do believe that you can also get 'pre-finished' bearings that should be the correct size once fitted. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 27, 2015 Share Posted July 27, 2015 Anyone want a set of cam bearings? I bought a set just in case when I rebuilt the 4.6 but didn't use them in the end. From V8Tuner, the type that don't need boring. Quote Link to comment Share on other sites More sharing options...
cold_n_wet Posted July 29, 2015 Author Share Posted July 29, 2015 Thanks chaps :-) Ill pass on the info. Quote Link to comment Share on other sites More sharing options...
