Hybrid_From_Hell Posted August 23, 2015 Share Posted August 23, 2015 "Bugger" sums up yesterday. Was trying to sort the clutch out, tried new master didn't sort it, and was looking then to change the slave. Lots of starting testing stopping etc. The 90 has been doing odd things recently. The fuel guage has stopped working for no reason, then starts again, windscreen wipers crack fuses now and then, engine just cuts outs, then restarts, looked and looked but not found any real reasons why... Then yesterday cranked it and nope, won't start, cranked and cranked and then there was a loud "pop fizz" and smoke started pouring out of the dash area....LOTS of smoke,.... all dash lights went out and cranking stopped..and smoke f loads of it .... Hit the kill switch, .............but smoke continued. .........f eeek ! 1 x Extingusher did F all,..........my old Halon did, and the 90 was saved. It was a close thing. It was pushed back into the garage in disgrace. So, still don't know if clutch sorted no idea of the wiring damage or severity, but its loads. So its going to be looked at today when I drag it back out and see whats what Close call to close . Reminder for those who don't .............. have MORE than 1 extingusher............... and make sure they are BIG ones and easy access when it goes wrong it goes wrong fast big time and it seconds "Bugger" .... Bludy LRs Quote Link to comment Share on other sites More sharing options...
mad_pete Posted August 23, 2015 Share Posted August 23, 2015 Sorry to hear that Nige. Hope it's not too bad. Quote Link to comment Share on other sites More sharing options...
discomikey Posted August 23, 2015 Share Posted August 23, 2015 Note to self, prioritise wiring harness replacement! And get an stinguisher Glad to hear you managed to save it! Quote Link to comment Share on other sites More sharing options...
need4speed Posted August 23, 2015 Share Posted August 23, 2015 That's a bugger Nigel. Hope it's not as bad as you think................ But it probably is I've got an extinguisher but after your story I'm doubting it would be man enough for the job.. Quote Link to comment Share on other sites More sharing options...
missingsid Posted August 23, 2015 Share Posted August 23, 2015 Or keep your old ilegal Halon, yours must be as old as mine is as they stopped use twenty odd years ago! I was given two by my company when they had to remove them all. Glad your vehicle was saved. Parent type comment, the intermittent faults and fuse failiure was a warning! Marc. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 23, 2015 Share Posted August 23, 2015 Sorry to hear that. Puts my simple MOT fail into perspective! I made up a set of sill bars for a defender owner once - a fireman by trade - and his advice mirrored yours - Two extinguishers, always. G. Quote Link to comment Share on other sites More sharing options...
deep Posted August 23, 2015 Share Posted August 23, 2015 I've had an extinguisher not work when needed. Turns out the cheap and popular dry powder type can pack down with the shaking of a vehicle and so becomes more useful as a paper weight! So good you had a spare. Makes me think it must be time to replace mine... Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 23, 2015 Author Share Posted August 23, 2015 Hmmm "Today I have mainly stripping my LandRover" .............. The entire dash is out, and I then saw the problem. yes its finest 1980 LR bodgifications of wiring, the main wires PRE fuse box have chaffed against the bulkhead doing a big F short, followed by some wire meltings into others. The good news is as I caught it super quick, and chilled it even quicker is fixable I think without major major work, just er major work. Its also one of the wires that was the main feed to the ECU - cough - unfused - so a new EFI system is the order of the ...future. So Have stripped off all the old EFI Loom, which I wasn't happy with anyway, and stripped the dash out and snipped out some of the toasted coupling and spread wires about to see whats what. Job one is the completely build a new MS loom, so may do a pic build as I have some ideas I want to try out, I am also going to use both an MS1 and also as I have been toying with the idea MS2 as well, and then run autotune, / set up etc etc and roling road to see what BHP / Torque I can get from each system. I am often told MS2 is so much better - well I am going to try each with some facts (facts and provable data is so unfair in a arguement eh ) and lets really see !I have my order in for a Built MS2 + EDIS 8 and the game is on. "Some work" doesn't sum it up, still have to see if the new Master and slave has fixed clutch issue - but for that I need a running engine !hey ho and "Bugger" ...could have been far worse ! Loom off / bonnet off, engine loom off : all the "Extras" (ARB winch air freespools fans etc all OK, cut EFI out of the unit and removed some time later : This is a main from ignition switch / pre fuse box, this melted lots of other wires some badly some a bit, needs a load of time and repauiring and double checking : this was melted / stuck to loads of other wiring some also badly melted into one mess : possible culprit this is FACTORY - like a strip of meltal, folded over and sharp edges with some cloth tape wrapped around it ! up agsinst the steel bulkhead - no problem there eh ? Burn marks through the paint on the bulkhead : "Work in progress area" : :rofkl: So, engine loom 1st ....more to come... Quote Link to comment Share on other sites More sharing options...
discomikey Posted August 23, 2015 Share Posted August 23, 2015 this is exactly why i am creating a new harness from scratch, to work to better standards than LR and also to incorporate more modern connectors for ease of servicing/removal etc. hope you get sorted soon Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 23, 2015 Share Posted August 23, 2015 Crikey Nige, gutted, but from the looks of things could have been a LOT worse. Having just done the engine loom on the ambulance I was surprised to re-discover all the things LR DON'T bother fusing. From what I can tell the biggest problem is the main loom feed from the starter post has no fuse, followed by the ignition live circuit (probably that white wire you found) which is just the un-fused 12v coming through the ignition switch. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted August 23, 2015 Share Posted August 23, 2015 Glad the 90 survived! Be very careful with the burnt bits, there's a risk of hydrofluoric acid contamination, wear some gloves! Mike Quote Link to comment Share on other sites More sharing options...
