Transfer box numbers
Ozzy50
Not sure if I have put this in the correct place ?
Simple question, I hope ,how do I identify what ratio a transfer box is ?,I am having a scrap out ,again ,and appear to have at least half a dozen lt230 transfer boxes and I would like to identify what they are ,I know I should of labelled em when I put em away but I didn't ,I can see an id number on one of the casings but not on the others ,can anybody help please .Also is there any companies that buy them for rebuilds ,Ashcroft or someone like that ?
Cheers ,James
From: http://www.ashcroft-transmissions.co.uk/index.php?act=viewProd&productId=45
LT 230 Ratios
12D = 1.667
13D = 1.410
14D = 1.003
15D = 1.192
20D = 1.667
21D = 1.667
22D = 1.410
25D = 1.410
26D = 1.003
27D = 1.192
28D = 1.222
29D = 1.192
32D = 1.222
36D = 1.211
37D = 1.211
38D = 1.211
40D = 1.211
41D= 1.211
43D = 1.410
47D = 1.667
57D = 1.410
59D = 1.211
61D = 1.211
62D = 1.211
68D = 1.211
69D = 1.211
70D = 1.211
80D = 1.211
81D = 1.211
It's till possible. I've looked and looked and looked at it and I'm sure it's 28, the label appears correct on it though, 1.192
Hi,
the web list is a simplified version :
28D, sx B = 1.192
28D sx C to 308626E = 1.222
28D309143E to 551442F = 1.208
the above was then superceeded by the 36D in the disco 1's which were 1.211 (Q gears)
differences were tooth pressure angles and tooth count and tooth width, all changes were to reduce noise, the 1.211 (also used in the D2's and TDCi defenders) are the quietest but also have the weakest teeth as the teeth are smaller as there are so many more of them than the earlier ratios,
Dave
Dave
  • 5 years later...
Hi,
I just got my hands on a LT230. It has the following serial number: 36D667628G.
 I suspect is a 1.211 ratio and it is a Q box (T design with more silent gears).
Can any help on when it was produced?
What vehicle it was fitted to?
Any things to be aware of on this transfer case?
Any other relevant info.?
Thanks Rasmus
