landroversforever Posted November 30, 2015 Share Posted November 30, 2015 Have any of you lot got any pictures looking from the bulkhead towards the LT230 with the seatbox mounted? I need to see what space there is around the LT230 in the seatbox opening to clear my new gearbox mount. Failing that, has anyone got a mint R380 seatbox? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted November 30, 2015 Share Posted November 30, 2015 Probably not exactly what your after as mine is an lt77 seat box and tunnel but there is a fair bit of room around it. I beleve the r380 has more space? HTH Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 30, 2015 Author Share Posted November 30, 2015 Thanks, but I need the view the other way. IE looking at the face of the LT230. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted November 30, 2015 Share Posted November 30, 2015 Have any of you lot got any pictures looking from the bulkhead towards the LT230 with the seatbox mounted? I need to see what space there is around the LT230 in the seatbox opening to clear my new gearbox mount. Failing that, has anyone got a mint R380 seatbox? Thanks in advance! You can just modify your existing seatbox with the R380 plate - drill out the spotwelds from a tatty box and transfer the plate to your current box and trim the seatbox away where needed. Landrover used to do this themselves with the 300tdi Repower kit and supply the plate as a spare part. I've just condemned yet another rotten 300tdi 90 yesterday if you need a seatbox plate r380 plate. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 30, 2015 Author Share Posted November 30, 2015 I don't want any joins, I want it with a factory tunnel. I just need to see what space there will be around the back of the box/adaptor in the R380 tunnel. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted November 30, 2015 Share Posted November 30, 2015 I don't want any joins, I want it with a factory tunnel.Good luck with that one then, as the factory are still this day knocking out the same lt77 seatbox with the r380 adaptor spotwelded onto it hidden under the soundproofing mat Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 30, 2015 Author Share Posted November 30, 2015 Yeah the lip is probably spot welded on, but the hole for an LT77 is far far smaller so you wouldn't be adding stuff to fit an R380 tunnel. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted November 30, 2015 Share Posted November 30, 2015 Ross this may or may not help you but I have a mould for an R380 tunnel and bulkhead flange. Mike Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 30, 2015 Author Share Posted November 30, 2015 I'm awaiting one of your tunnel flanges from TJ. however I'd quite like a tunnel as well at some point. I have a standard one for mockups/building around, but would be nice to swap out for one of yours at some point later in the build! Quote Link to comment Share on other sites More sharing options...
Buzza Posted December 2, 2015 Share Posted December 2, 2015 Are these any help, its a '95 300 tdi. Steve Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 2, 2015 Author Share Posted December 2, 2015 That's great thanks . Any chance of one from lower down on the second picture please? Cheers Quote Link to comment Share on other sites More sharing options...
Buzza Posted December 3, 2015 Share Posted December 3, 2015 Try these Steve Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 3, 2015 Author Share Posted December 3, 2015 Absolutely Perfect! Many thanks Steve Quote Link to comment Share on other sites More sharing options...
