Timdiver99 Posted November 30, 2015 Share Posted November 30, 2015 Hi, I bought my TD90 in September 2015, fully Mot'd(!) but once on the road, the fuse for the indicators, guages and brake lights (no 5, 15 amp) keeps blowing. It blows when I operate the indicator switch - it's fine at a stand-still, but blows on the move! I've checked that the indicator lights are all getting power, and that they are all earthed. I have read that the hazard switch (through which all the wires pass, I'm told) can be a weak point. Will replacing this switch cure my problem? If not, I reckon that a wire must be shorting somewhere in the loom near the fuse box. The wires pass through the bulkhead in a thick bundle, but without removing the dash, I can't really inspect any more than the first couple of inches of the loom. If that's the case, please can anyone let me know how to remove the dash? I've got the grab handle (passenger side)and heater controls (driver's side) off, but can't see what else I need to undo to get the dash to pull away. Any help would be brilliant. Thanks, all. Tim. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 30, 2015 Share Posted November 30, 2015 Tim, take your 90 out of the water and dry it out thoroughly. That should solve your fuse blowing problems ? Mo Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted November 30, 2015 Share Posted November 30, 2015 Which part of the dash are you looking to remove? if you want to remove the whole lot then it's easier to start from the top down. Part of the loom goes from the fuse box through a large centre grommet to the engine bay but the rest runs along the top of the lower heater duct/plenum up behind the instruments, I'd suggest looking at the wiring around the steering column/behind the instruments etc before ripping the rest of the dash out. If it's only tripping when driving (ie steering) can you get it to blow if stationary then going from lock to lock? Quote Link to comment Share on other sites More sharing options...
western Posted December 1, 2015 Share Posted December 1, 2015 & have a read of http://forums.lr4x4.com/index.php?showtopic=25376 Quote Link to comment Share on other sites More sharing options...
