ianmayco68 Posted May 1, 2016 Share Posted May 1, 2016 Hi all, upgraded the gearbox on my 110 200tdi project to an r380 stumpy from Ashcrofts and I'm just fitting my new wiring loom came to wiring the reverse in off the gearbox and I'm stuck . I've got 2 black wires coming off the gearbox and a black/blue trace off the chassis loom, do I connect one of the wires from the gearbox to the black/blue wire and then earth other or connect both to the black/blue wire ? any help would be much appreciated cheers Ian Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted May 1, 2016 Share Posted May 1, 2016 Black and blue is the Diff lock warning light... Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted May 1, 2016 Author Share Posted May 1, 2016 Cheers vulcan bomber sort of stumbled on to that one just whilst doing the td5 clocks upgrade, as you can tell I'm a novice at this. So what are the colour of the wires that the wires off the gearbox need to be attached too ? As the extension supplied with the new loom that goes from the main loom on to the gearbox is also 2 black wires All help much appreciated cheers Ian Quote Link to comment Share on other sites More sharing options...
western Posted May 1, 2016 Share Posted May 1, 2016 look for plain green =12v from fusebox & green/brown trace to reverse lights Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted May 1, 2016 Author Share Posted May 1, 2016 cheers western sorted that one. Got another one, the connections for the rear lights are as far as I have found out red , green/purple trace black = side/ stop lights red/yellow trace fog lights green/white and green/red indicators green/brown trace reverse what are the red/black trace wires for ? cheers Ian Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted May 1, 2016 Share Posted May 1, 2016 Pretty sure that's side light feed... However, if you have a quick Google. The wiring colours are pretty standard. Quote Link to comment Share on other sites More sharing options...
western Posted May 1, 2016 Share Posted May 1, 2016 Red/black = LH tail light & reg plate light Red/orange = RH tail light green/purple = brake lights green/red = left rear indicator green/white = right rear indicator green/brown = reverse lights red/yellow = rear fog Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted May 1, 2016 Author Share Posted May 1, 2016 Cheers all much appreciated 1 Quote Link to comment Share on other sites More sharing options...
