diggervan Posted May 1, 2016 Share Posted May 1, 2016 Does anyone know what the symptoms or if you think you're accelerater pedal on its way out on a td5 Because mines doing some strange things just lately (no oil in loom or in the red ecu plug) Any suggestions would be great thanks Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted May 1, 2016 Share Posted May 1, 2016 From the ones I've experienced, hesitant or jerky response, usually followed by an inability to rev. Quote Link to comment Share on other sites More sharing options...
diggervan Posted May 2, 2016 Author Share Posted May 2, 2016 Yes just as I thought it's acting almost as you descried but sometimes it'll put engine management light on so I have to turn lignition off and on again Also when cruising with foot just on the pedal if you go to accelerate it doesn't miss as sutch it skips a beat if you know what I mean So the question is now genuine part or are the after market one's just as good Thanks Bob Quote Link to comment Share on other sites More sharing options...
TobyMellin Posted May 10, 2016 Share Posted May 10, 2016 Mine used to occasionally completely stop working and bring on the engine management light whilst driving. Turn off engine, start up and it was fine for a while. I just ended up replacing with a new pedal. Toby Quote Link to comment Share on other sites More sharing options...
tacr2man Posted May 10, 2016 Share Posted May 10, 2016 Might be worth checking connector plug for corrosion, had that with 300tdi edis type Quote Link to comment Share on other sites More sharing options...
