sighnbox Posted May 23, 2016 Share Posted May 23, 2016 Ok guys she been good for a while BUT every now and then I turn the ignition key key and NOTHING happens at all......All the power is there but she dont turn over ....Rapid turn the key and then she starts this has been going on for well over a year now but as 99% of the time it starts so I've not done out about it ....Speaking to others who had this problem a push button start (Still using the key for power) seams to cure this. Do I need a special button as I'm presuming a standard momentary 2 pole switch will do ? Do I need a relay or not ? Fussed or not ? What gauge wire do I use ? and of course what do I connect the switch to I presume one end to the trigger wire/spade end wire to the started motor the other end some where else on the ignition ? but what wire ? Thanks there every one Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 23, 2016 Share Posted May 23, 2016 How's about just change the ignition switch? Quote Link to comment Share on other sites More sharing options...
sighnbox Posted May 23, 2016 Author Share Posted May 23, 2016 Yes very true but on me 3rd one and sick of changing them and spending a bomb on them + changing all the door locks ......£10 button far easier Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 23, 2016 Share Posted May 23, 2016 Change the ignition switch not for one in a blue box? Quote Link to comment Share on other sites More sharing options...
sighnbox Posted May 23, 2016 Author Share Posted May 23, 2016 LOl your prob right had that with the dip switch keep 't blowing them till got a lucus one Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 24, 2016 Share Posted May 24, 2016 you do know you can just replace the switch and not just the whole lock mechanism? - its held in with 2 small screws and just pull out... http://www.ebay.co.uk/itm/PRC8230-Land-Rover-Defender-Steering-Lock-Ignition-Switch-200-300-TDi-TD5-/291617753245?fits=Car+Make%3ALand+Rover&hash=item43e5c5c89d:g:QnAAAOSwRLZUID~Q Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted May 24, 2016 Share Posted May 24, 2016 ...just watch out for the little floating adapter piece that fits between the end of the key barrel and the switch which has a habit of falling out and burying itself at the bottom of the snakes nest behind the dash. Quote Link to comment Share on other sites More sharing options...
Arjan Posted May 24, 2016 Share Posted May 24, 2016 Nothing wrong with push buttons.... Manually operated glowplugs & starter.. Quote Link to comment Share on other sites More sharing options...
pat_pending Posted May 24, 2016 Share Posted May 24, 2016 Have you actually established it's the ignition switch that's at fault? Because if you haven't you may be wasting your time fitting a button, which IMO is a bodge anyway. Diagnose the fault properly and then repair it with decent quality parts. Quote Link to comment Share on other sites More sharing options...
Flash17 Posted May 24, 2016 Share Posted May 24, 2016 I had similar for a couple of months with an intermittent fault before it failed to start completely, after swapping out the ignition switch for a Lucas item it still refused, the penny dropped when I stuck a test bulb between the spade connector on the starter solenoid and earth and it showed nothing when the key was held at crank, the starter relay was clicking so I'd assumed it was alright but the contacts were shot. a new relay sorted it. A cheap and quick way to eliminate the starter relay....swap it round with one of the others. May just be worth a try good luck. if you are looking for push buttons, I've used water proof ones for marine environments, you can find being sold in boat chandlers, cheap and robust. Quote Link to comment Share on other sites More sharing options...
sighnbox Posted May 25, 2016 Author Share Posted May 25, 2016 Are well will replace the starter relay first then so next question which one is that ??? Quote Link to comment Share on other sites More sharing options...
western Posted May 25, 2016 Share Posted May 25, 2016 the relay with thick white/red trace & plain brown wires going to it's base socket. Quote Link to comment Share on other sites More sharing options...
sighnbox Posted May 29, 2016 Author Share Posted May 29, 2016 Thanks Ralph Yes found it by pulling them out and interestingly with it out its acting exactly the same as when I turn the key and nothing For those interested its the green one on the end Just in-case knowing my luck its not the relay The ignition switch is that a Pre TDI one a TD one???? (My landy a 1990 TD Converted to a 200tdi) Quote Link to comment Share on other sites More sharing options...
sighnbox Posted May 29, 2016 Author Share Posted May 29, 2016 Just checking the starter Relay is that Green type (YWB10032L) Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 29, 2016 Share Posted May 29, 2016 If you're burning out that many switches, then it suggests a short between the switch and the relay. I see the permanent live to the switch has also burnt, which suggests loom damage too. Quote Link to comment Share on other sites More sharing options...
sighnbox Posted May 29, 2016 Author Share Posted May 29, 2016 On the old ones it was the actual ignition barrels that gave out not the switch .........I brought the new relay YWB10032L relay today...If that dont work then will replace the switch .........It will start 10-20 times fine then get the odd time turn the key and power is there but thats all that happens no click nothing ......rapid turn the key back and forth some times just 3-4 times other's 20 times and she will start .........turn it off ...turn the key again and starts fine. Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 30, 2016 Share Posted May 30, 2016 If the switches are Britpart, then it could be them. I had no end of trouble trying to adjust a Britpart brake light switch, which ended up in the bin, replaced by a genuine one, which was a doddle to set up. Quote Link to comment Share on other sites More sharing options...
sighnbox Posted May 30, 2016 Author Share Posted May 30, 2016 Are thanks for that not ordered a switch yet as say trying the relay first and yes think they were ****Part .....will use Lucus or Bearmach .......But I know exactly what you mean as I had big trouble blowing main beam dip switches I think it was three I had in less than 18 month ......changed to a Lucus one ended the problem years later all still fine. Quote Link to comment Share on other sites More sharing options...
western Posted May 30, 2016 Share Posted May 30, 2016 my 110 is a ex TD with a defender spec 200tdi, Still use the original ignition switch which works fine, there's a post for the wiring connections on the back, the thick red/brown is removed as it was the glowplug power feed, replaced by the Tdi's glowplug timer unit & assocoated wiring. http://forums.lr4x4.com/index.php?showtopic=9354&hl= Quote Link to comment Share on other sites More sharing options...
sighnbox Posted May 30, 2016 Author Share Posted May 30, 2016 One thing I have noticed is that switch of mine does NOT have the raised sliding bar on one side the screw goes in to.....mines just round with a screw hole each side (I could be imagining that )...........so hope a Lucus one with the bar will fit (If I need it but its going to be the relay fingers crossed) Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 31, 2016 Share Posted May 31, 2016 For what it's worth, my 109 still has its original (2.25p) ignition switch, despite running a Tdi since 2008 and a 12J before that since 1994. That is without a relay between the switch and starter solenoid. I still think you need to investigate the wiring between switch and relay to see if there is a short. Quote Link to comment Share on other sites More sharing options...
sighnbox Posted June 8, 2016 Author Share Posted June 8, 2016 DARE I say it new relay in and so far so good .........after all that 2 Quote Link to comment Share on other sites More sharing options...
