Yolandi Posted May 26, 2016 Share Posted May 26, 2016 Hi all, iv fitted an oil sandwich plate and oil temp and pressure gauges to my 110, so far, apart from the odd oil dribble, its been working great, however if i turn the side lights on or press the brake the pressure gauge dips and the temp gauge rises a bit, turning on the main lights causes the same but dips and riaes further (until the pressure is reading negative), i dont know what to do about this, for the gauge power i spliced into the power for the stock gauges and for the back lights i spliced into the stock backlights wires Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted May 26, 2016 Share Posted May 26, 2016 Mine did this until i took a better positive feed to them as voltage drop makes temp gauge rise slightly Quote Link to comment Share on other sites More sharing options...
Yolandi Posted May 26, 2016 Author Share Posted May 26, 2016 How exactly did you wire yours? Quote Link to comment Share on other sites More sharing options...
Arjan Posted May 27, 2016 Share Posted May 27, 2016 Gauges like, in general, a stabilized feed. Often, when switching on lights, the gauges will read higher because the voltage drops a bit. Like he said, separate feed / stabilizer usu do the trick. Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted May 27, 2016 Share Posted May 27, 2016 Yolandi i used a relay off the battery and used an ignition feed to turn relay on Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 27, 2016 Share Posted May 27, 2016 Check the engine earth too. Quote Link to comment Share on other sites More sharing options...
