Copey89 Posted May 27, 2016 Share Posted May 27, 2016 Hey, i have an oil leak down the left hand side of my engine (as you look at it from the front) looking at it, the engine is a 200tdi engine, the leak looks like it might be from the oil cooler pipes, or that general oil filter area, i plan to rip apart the whole lot and replace every gasket and seal i can and was just wondering if anyone has a list of everything that could be replaced, just so i can order it all and get it done in one hit, or am i best buying a full bottom end gasket set, like this one http://www.ebay.co.uk/itm/Land-Rover-Defender-200-TDi-Full-Bottom-End-Gasket-Set-STC1557-STC363-/320835188843?hash=item4ab344786b:g:MGUAAOSwDuJW1xOA thanks for any help Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 28, 2016 Share Posted May 28, 2016 The gasket sets are helpful, but it doesn't include the oil filter to block housing gasket... Quote Link to comment Share on other sites More sharing options...
mmgemini Posted May 28, 2016 Share Posted May 28, 2016 If the oil leak is above the filter, on the filter housing. Check that the housing hasn't cracked where one of the oil pipes fit. You will need to take everything off to check HTH Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted May 28, 2016 Share Posted May 28, 2016 Breather pipes are a classic leak area... Quote Link to comment Share on other sites More sharing options...
Copey89 Posted May 28, 2016 Author Share Posted May 28, 2016 Awesome, thanks for the advice guys, i will check it all in thd morning Quote Link to comment Share on other sites More sharing options...
monkie Posted May 28, 2016 Share Posted May 28, 2016 Before you spend any money on parts, I think it will help you to identify the exact point of the leak if you give the whole area where the oil seems to be coming from a real thorough clean. It should then be a bit more obvious where the oil is coming from (and to what extent) when you take it for a drive post the clean up. Obviously a gasket set won't be a lot of help if it is a loose or broken pipe. HTH Quote Link to comment Share on other sites More sharing options...
